please help! changed rotors and pads but pedal still shakes bad
Old 09-08-09, 09:39 PM
mikemareen
mikemareen's Avatar
Default please help! changed rotors and pads but pedal still shakes bad
I swear this shop I went to has to be the most in-competent group of idiots ever...I don't even know if I should take it back.
I got new oem pads and new aftermarket rotors replaced about 2 months ago... but now it's starting to shake real bad when I brake. In fact, the brakes just feel like crap.
does anyone know what went wrong ? why is my car still shaking when I have brand new rotors and new oem pads. did they not tighten up the expansion bolts properly ? I also had them bleed the brake system, did they not bleed it properly ?
Old 09-08-09, 11:58 PM
KILLERGS4
KILLERGS4's Avatar
sounds like the problem is the aftermarket rotors... are they cross drilled?
Old 09-09-09, 12:16 AM
Red Square
Red Square's Avatar
thats weird if a new pad or even 'aftermarket' rotor would go bad in 2 months. might want to double check if your suspension components are all thighten down correctly. also a bad shock can cause vibration during hevy braking (usually down hill braking).
Old 09-09-09, 04:34 AM
AlexusAnja
AlexusAnja's Avatar
Does it only shake when you brake or all the time? I would check the easiest, to make sure all your lug nuts are tight. Maybe they didn't tighten it properly. Most shops don't hand tighten the nuts first then put the pneu. gun to it, they just put it on right from the start. May times stripping the nuts.
Anyway, if you can't isolate it, bring it to a different to get looked at.
Old 09-09-09, 09:48 AM
mikemareen
mikemareen's Avatar
no they are just standard rotors from ebay
Old 09-09-09, 09:50 AM
mikemareen
mikemareen's Avatar
it's only when i brake so it's isolated to the braking system
Old 09-09-09, 10:09 AM
I6turbo
I6turbo's Avatar
Now that the problem has been successfully diagnosed, go get some quality rotors -- OEM is highly recommended -- and finish the job.
Serioulsy, this isn't an uncommon occurrence with aftermarket rotors -- even the name brand aftermarket stuff. I can't tell you how many times over the years I've seen this on performance car boards such as Supraforums.com. People keep "warping" rotors -- even Brembo and the like -- and keep scratching their head and asking What's wrong??? Get something of known quality or else it's a crap shoot. Brake rotors look simple enough, but there's more to making a good one than just melting a hunk of iron ore and then machining it.
Old 09-09-09, 10:46 AM
AlexusAnja
AlexusAnja's Avatar
Default Its for forging process
totally agree. If it's just during braking, then the rotors, although not that old, are probably warped. Making rotors isn't just stamping out a piece of metal into a circle. It takes the proper mix of metals, forging, and then machining and heat dissipation properties. Don't know how much you got off Ebay, but the rotors are like $108/140 (f/r) at irontoad.com. Not sure why the bigger fronts cost less...
Old 09-09-09, 11:01 AM
vcheng
vcheng's Avatar
In addition to using OEM parts as already stated by others, please pay attention to the following:
Make sure that the hub surface against which the rotors seat is cleaned of any corrosion or debris to help proper seating. The back of the alloy wheels that seat against the rotors should also be cleaned properly.
Make sure that the wheels are torqued properly using a calibrated torque wrench. No air tools or torque sticks should be used in tightening. All lug nuts should be threaded by hand, and then hand tightened using a star pattern in three stages to 85 ft-lbs. This torque setting should be rechecked after driving about 100-150 miles.
Good Luck!
Old 09-09-09, 11:07 AM
sojah
sojah's Avatar
the problem is obviously rotors, like many have mentioned. a cheap knock off rotor can warp in an hour so it doesn't matter how old or new they are. i wasted a lot of money last year on aftermarket rotor setups on my old gs400. i ended up with a set of oem blank brembo rotors that were like 40$ each. best set of rotors i've ever owned.
there is a valuable lesson to be learned here and i think i6turbo knows what i'm talking about.
Old 09-09-09, 11:12 AM
mikemareen
mikemareen's Avatar
ok thanks guys, do u guys think I can still turn these rotors ? or will they just warp fast again ?
Old 09-09-09, 11:56 AM
dis 4 duc
Registered User
dis 4 duc's Avatar
check your wheels, could be bent if u got into a recent accident, or what not, hope that help, go to a place to see if they can balance your wheel
Old 09-09-09, 12:39 PM
I6turbo
I6turbo's Avatar
If they started out running smooth (not warped or unevenly worn, or whatever it is that happened to them) I'd guess that they'll warp again even if you could turn them down to get a flat surface. Not sure, but I wouldn't spend the time and money on the turning. In fact, I'm not a believer in turning rotors anyway -- if they are acting up, I just replace them. What little experience I've had with turned rotors turned me off of turning 'em.
Old 09-09-09, 12:41 PM
sojah
sojah's Avatar
yeah what he said ^ ^ ^, plus turning rotors in my past experience was like $100+ and it was cheaper for me to get all new brembo oem blank rotors, which are the best i've come across.
Old 09-09-09, 04:06 PM
mikemareen
mikemareen's Avatar
it's not the wheels, it only happens when i hit brakes
Quick Reply: please help! changed rotors and pads but pedal still shakes bad
