what about this 02 LS430
Got one 02, LS430, not sure if it is ultra package, but the mark ivension sound syste, and all look very nice. 110000 miles, Black out, while in. But Timing belt has not been changed yet. $11900.
What you think guys?
thanks
thanks
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
That timing belt is costly sir! If you don't mind replacing it,OK! I had it changed at 90,000 miles! Yes, if you don't mind changing it! I feel they are passing the buck on changing the timing belt! Again, if you dont mind replacing it on your dime yes! If you do mind no! Call the dealer or a mechanic to see how much it may cost to replace it and if its worth it before you decide! I forgot what I paid but remember it was costly!!! Did it with the 90,000 mile service and it was over $1,000 total sir! All the best!!! L.G.N.M
That timing belt is costly sir! If you don't mind replacing it,OK! I had it changed at 90,000 miles! Yes, if you don't mind changing it! I feel they are passing the buck on changing the timing belt! Again, if you dont mind replacing it on your dime yes! If you do mind no! Call the dealer or a mechanic t see how much it may cost to replace it and if its worth it before you decide! I forgot what I paid but remember it was costly!!! Did it with the 90,000 mile service and it was over $1,000 total sir! All the best!!! L.G.N.M
Shop around.
Thanks Guys
I have found a reputatble mechanic who can changed the timing belt,water pump and motor belt for around $750.00 to $800.00 total ( parts will get from the dealer).
