How to remove console in 2001 430
I need to remove my center console to remove loose change that has fallen inside so the cover will open all the way, also i think cupholder is jammed because of coins. need step by step instruction. Thank You
Unscrew the shift ****, then remove the little piece just in front which has the heated seat controls. It just clips in on either side. If you open the small drawer just above it you can pressure the right side out first. Then remove the larger piece with shift bezel. It also clips in. Then you can see the cupholder mechanism, which is secured by(I believe) two screws.
Easy 10 minute job.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
If you cant get the front piece off, you can loop a string behind it and pull.
Good luck,
Alan
Easy 10 minute job.
Good luck,
Alan
amati5
SC- 1st Gen (1992-2000)
27
11-20-01 09:20 AM
