Headlight Adjustment
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
A few weeks ago the headlight adjustment light along with the the warning signal . It keeps getting worse. Since then it has gotten worse and the signal comes on about every two minutes. The headlights do not seem to be out of adjustment. Can anyone help? It's driving me crazy
Not when the AFS warning light is popping up, you will need to go to the dealer to find out which sensor (front or back) is malfunctioning. It won't be cheap if your warranty is expired.
1st- You will need a ratchet & a 10mm socket
![](http://i8.photobucket.com/albums/a13/teehtf/11-8-200910-27-24PM.jpg)
2nd- Park on a flat surface in front of wall with headlights on.
3rd- Behind each low beam headlight there are holes, stick the ratchet socket into the hole and turn to adjust the desired height. This will also adjust both low and high beams at the same time, that's it you are done.
Okay then you are in good shape, you just need to re-aim your off headlight which easy enough.
3rd- Behind each low beam headlight there are holes, stick the ratchet socket into the hole and turn to adjust the desired height. This will also adjust both low and high beams at the same time, that's it you are done.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Are you saying both high and low beams height are moved at the same time with the single adjustment?
How about left or right adjustment?
Thanks for helping one who is easily confused,
Alan
Tee, is there a rule of thumb as to where headlights should shine on the roadway (how far ahead, left or right, etc for each side, both low and high beam? Should the high and low beams both point to the same area?
I don't know what the rule of thumb is but after I adjusted mine (b/c the factory aimed them to low) I went for a quick drive thru the subdivision several times until I got them where I liked.
Yes, if you want to adjust them separately it more labor intensive.
There are no left right & right adjustments.
01, 350, adjust, adjusting, adjustment, adjustments, beam, frontier, headlight, headlights, height, lexus, nissan, rx, sc300
