Can I lock my LS from outside when the engine is running?
Its going to be "our first winter together" and I was wondering if there is a way to start the car and lock it from the outside so that it can warm up in the morning without someone driving it away. The smartkey system is pretty smart in preventing something like this from happening, but has anyone found a loophole?
back to basics...use the KEY
I DID find that, with the engine running, you can MANUALLY lock the doors with the traditional (metal key) portion of the key. Then...to unlock, you need to use the traditional key portion again and manually unlock it.
There still might be another way with the remote fob, but I didn't seem to find one...plus it's chilly outside right now.
the key is key
Best bet is to use the metal (key) portion of the keyfob to lock her up...HOWEVER...I found the smart key (proximity) does not work when you return to unlock her. You must use the metal (key) portion of the fob to unlock her.
I will have a remote starter (comes with my new alarm system & pager) installed this week. This high-end alarm system is able to "learn" the starter code as to never needing the smartkey.
The doors will be locked and the alarm will still be armed.
I'll let you know how it works out!
Interesting post. I found this to be annoying myself on certain occasions, especially since the smart key system allows the car to be driven with out the key actually in the car.
I have not tried this myself, but you might be able to turn off the smart key access (which is rather easy to do) after starting it, then be able to lock the keys with the fob. I'll have to try this next time I get into my car.
