Lower Control Arm Bushing Repair
Old 04-04-22, 05:07 AM
  #286
nvwls
nvwls's Avatar
While this thread is bumped...My experience with the GSF/RCF bushings has been interesting. When I first installed them, the only new suspension component on my car at 135k miles was the front struts. At that time, installing these bushings helped tighten up the steering and gave a more confident ride, which was a welcome change. Prior to that, the car was indeed very boat-like and uncomfortable to drive at higher speeds. However, in the past 1.5 years since I have replaced the entire front end and the rear struts. I'm increasingly becoming of the opinion that the steering feedback and feedback from the GS-F/RC-F bushings are a bit too rough for the LS. I'm assuming their suspensions were designed with these in mind, but now that the bushings are no longer compensating for any slack elsewhere, they mess with the "synergy" of originally engineered suspension.
Old 04-05-22, 03:20 PM
  #287
bigal426
bigal426's Avatar
novels, I suppose that could be true. I installed my bushings almost 3 years ago and some 30,000 miles, and have everything else stock on the suspension, but I have changed the lower ball joints with Genuine Lexus parts. I have purchased the upper control arms, but have not needed them as of yet. I have 156,000 on the clock on my 02 LS430. Good luck.
Old 04-16-22, 02:17 PM
  #288
ls430w140
ls430w140's Avatar
Try ISF bushings. This is the best decision i made so far to compliment the Tein shocks that i have in the suspension. Great responsive suspension, very comfy (correctly setup).
uberfuzz (10-06-22)
Old 04-21-22, 08:33 PM
  #289
xjfish
xjfish's Avatar
I have put almost 20k miles on the GSF bushings now. I think they work great. For comfort maybe a bit harsher than stock? Handling, stability, steering, and steering feedback good IMO.
Old 10-04-22, 05:13 PM
  #290
Tom57
Tom57's Avatar
Originally Posted by rkw77080
Here are the torque specs for the 2 mounting bolts...
Is there a specified torgue sequence for the large nut and 2 bolts that hold the LCA bushing and bracket? I assume the nut for the bushing should be tightened and torqued first since it is lateral to the bolts. How about the bolts?
Old 10-04-22, 05:34 PM
  #291
Received 1,193 Likes on 887 Posts
No the nut is last, and only tighten it when the car suspension is at normal ride height
Old 10-04-22, 06:51 PM
  #292
Tom57
Tom57's Avatar
Thanks for your reply. Interesting that the nut is last. Tightening the bolts first prevent the nut from fully tightening down on the metal center hub of the bushing. Tightening at normal ride height is typical for suspension bushings / control arms. Thanks again.
Old 10-04-22, 07:37 PM
  #293
It shouldn't prevent that.....you can also very carefully mark where the arm sits relative to the bushing when loaded and tighten it there so that it corresponds to the car when sitting at normal ride if you want to tighten the nut first. You also are aware the bushing wants to be installed to the bracket in a particular orientation correct?
Old 10-05-22, 06:55 AM
  #294
Tom57
Tom57's Avatar
I torque the LCA bushing bracket with the car sitting at normal ride height. And yes, I'm aware the bushing must be oriented correctly when squeezed into the bracket. Thanks again for your replies.
Old 10-05-22, 07:39 PM
  #295
Tom57
Tom57's Avatar
I torqued the bolts first, then the nut on the LCA bushing with the car on its wheels. I'm getting an occasional creaking sound on light bumps.
Old 10-05-22, 08:39 PM
  #296
ls430w140
ls430w140's Avatar
This could be something In between the bushing bracket and subframe. Try to retorque those bolts again.
Old 10-07-22, 07:55 PM
  #297
Tom57
Tom57's Avatar
I'll re-install and re-torque the bracket bolts and bushing nut tomorrow. Is there a torque sequence for the bolts? 101 ft.-lbs. for the outer bolt; 44 ft.-lbs. for the inner bolt. 101 ft.-lbs. for the bushing nut.
Old 10-08-22, 09:48 AM
  #298
Tom57
Tom57's Avatar
Q: Are the LCA bracket bolts, LCA bushing nut and washer possibly one-time use only, like the brake caliper bolts?
Old 10-08-22, 02:41 PM
  #299
911LE
911LE's Avatar
No, they are not tty.
Old 10-08-22, 05:46 PM
  #300
Tom57
Tom57's Avatar
Default LCA Bushing Nut & Bracket
11.(a) Tighten the bushing nut.
11.(e) Tighten the bracket bolts (inner and outer).
Quick Reply: Lower Control Arm Bushing Repair
