Lower Control Arm Bushing Repair
Old 03-21-16, 10:27 AM
  #76
LiCelsior
Retired
LiCelsior's Avatar
Originally Posted by seve7
IM going to post here as this seems to be one of the more informative threads on the ls430 suspension. i drive my car for work, and dont plan on retiring it, but more or less doing a major restoration and rehab on it. the lcas are hard to find for a decent price, and really the only benefit to them is that they come with a new front bushing on it, camber bushing, or small bushing whatever you want to call it. the rear bushing has many vendors selling kits because this is the one to wear first because its "hollow" with a hydraulic fluid in it. but after some searching ive found a replacement for the front bushing. i cant find this on any parts catalogs or diagrams, its "part" of the lca it seems. http://www.ebay.com/sch/i.html?_from...+BUSH&_sacat=0
i was actually looking for this exact bushing. but only in the UK?
Linemanpjn (08-05-21)
Old 11-09-16, 03:29 PM
  #77
volson
volson's Avatar
Originally Posted by chunkyda
My bolts came off pretty easily. They are very clear of obstructions and nothing moves when the part is removed so I see no reason why a breaker bar won't get the job done. As long as you can get a hydraulic press you are OK.
The smaller inside bolt is 44 ft-lbs
The larger outside and middle of the rubber bolt are both 101 ft-lbs
is this the torque spec that others have used? I cant find much else on it. Just wanted to check before I drop it down.
Also 22mm and 17mm are the sizes.
Old 11-09-16, 05:37 PM
  #78
bmore430
bmore430's Avatar
FIGS has these bushings in 2 different poly materials already pressed in brackets for 360.00. You get 60.00 refunded if you return your cores. Saves labor and hassle of pressing the stock ones. I noticed my lower bushings had some small cracks forming so I will be placing an order this week for a set.
Old 11-09-16, 05:42 PM
  #79
volson
volson's Avatar
360 each or for the set? This is a really easy job if you have someone or a place that can do the pressing
Old 11-09-16, 06:37 PM
  #80
bmore430
bmore430's Avatar
That is for a set with billet or oem brackets. 300.00 for the pair if you return your old ones.
http://shopfigs.com/v3/index.php?route=product/category&path=41_122_238
Old 11-10-16, 06:57 AM
  #81
Johnhav430
Johnhav430's Avatar
http://shopfigs.com/v3/index.php?rou...ath=41_122_238
I am late to the game but interested....is there very little benefit to replacing the other bushings which come with new arms? Meaning if these get installed, 80%+ of the LCA issue is solved?? Here's one case where heck if aftermarket is superior to OEM, I'd go aftermarket...
Old 11-10-16, 08:35 AM
  #82
tradosauru
tradosauru's Avatar
Originally Posted by Lavrishevo
Do you need to change the whole arm? Most often only the large lower bushing needs to be replaced. Labor for both is about $250. You should also do an alignment.
http://www.ebay.com/itm/FRONT-LOWER-...dYFpCa&vxp=mtr
Old 11-10-16, 09:56 AM
  #83
bmore430
bmore430's Avatar
looks like typical Chinese eBay junk. price is cheap but not sure I'd trust them for a part so critical to the suspension.
Old 11-10-16, 10:15 AM
  #84
rkw77080
rkw77080's Avatar
Here are the torque specs for the 2 mounting bolts...
Old 11-10-16, 10:22 AM
  #85
Johnhav430
Johnhav430's Avatar
Actually, on eBay, I'm suspicious of multiple sellers (screen names), selling the same thing, from the same city in SoCal.....rather see the seller is somewhere else.
Old 11-10-16, 10:39 AM
  #86
tradosauru
tradosauru's Avatar
I was more surprised that the entire assembly could be bought. And the seller has over a 99% positive rating.
Old 11-10-16, 01:57 PM
  #87
volson
volson's Avatar
thanks! How about the bolt in the middle of the bushing? 101 again?
Old 11-10-16, 04:01 PM
  #88
rkw77080
rkw77080's Avatar
Here are torques pecs for the other specs...
LudeAEM (02-03-17)
Old 11-10-16, 04:27 PM
  #89
volson
volson's Avatar
thanks man!
Old 11-15-16, 07:22 AM
  #90
Daspyda
Daspyda's Avatar
Any idea what the ton capacity of the press needs to be to press out and re-install these bushings?
My shop has a 20 ton press - would that suffice?
TY!
Quick Reply: Lower Control Arm Bushing Repair
