Lower Control Arm Bushing Repair
Old 11-15-16, 07:35 AM
  #91
Daspyda
Daspyda's Avatar
Interesting read on DIY R&R on bushing using common tools: http://www.aftermarketsuspensionpart...thout-a-press/
Old 11-15-16, 07:47 AM
  #92
volson
volson's Avatar
Originally Posted by Daspyda
Any idea what the ton capacity of the press needs to be to press out and re-install these bushings?
My shop has a 20 ton press - would that suffice?
TY!
Yes. That is plenty. Just use PB blaster and fire as needed. (not at the same time)
Old 11-15-16, 07:53 AM
  #93
BradTank
BradTank's Avatar
TY!
For these, it's not so much about how many tons of pressure, but the if the press is big enough to accommodate it. If it's a freestanding floor press, it should be fine. If it's something for a tabletop it might be an issue. It's bigger than most bushings that are pressed in and out.
I had hoped I could use a control arm press to do the job but it simply wasn't big enough.
Old 11-15-16, 04:45 PM
  #94
HiloDB1
HiloDB1's Avatar
Old 11-15-16, 06:34 PM
  #95
bmore430
bmore430's Avatar
Originally Posted by HiloDB1
is that a figs bracket and bushings? looks like quality work. care to share?
Old 11-15-16, 07:44 PM
  #96
HiloDB1
HiloDB1's Avatar
Its all FIG's. I sent a set of lower control arms to them to modify and extend out the ball joint socket. The front bushing is a custom piece by them and also the rear bushing and housing is theirs. All my suspension components on my car are FIG's parts. I have FIG's FUCA, custom extended outer tie rods, FLCA, custom #1 bushing, #2 bushing in housing, RUCA, rear toe arm, rear track arm, and rear camber arm. Most parts were built custom for my application.
Old 11-30-16, 06:26 AM
  #97
Daspyda
Daspyda's Avatar
Thanks for all your guidance.
I obtained some OEM bushings off eBay a couple weeks ago, and had a local shop install them for $191 w/tax.
$138 for the bushings, $191 for the labor= $329 total.
Old 11-30-16, 09:37 AM
  #98
Tom57
Tom57's Avatar
That's a very reasonable cost.
Old 12-06-16, 12:09 PM
  #99
LudeAEM
LudeAEM's Avatar
So wait, this bushing comes off independently of the control arm? I was thinking of replacing the whole lower control arm but won't if it separates by itself.
Old 12-06-16, 12:33 PM
  #100
Johnhav430
Johnhav430's Avatar
I'm thinking about this more and more since I mounted my snows, I see mine are cracked. I believe it's the small ones facing forward that are not replaceable i.e. Toyota doesn't make the separate part, which is why dealers only replace the entire arm (does this make sense?). But the bang for buck improvement comes with replacing the rear larger bushing....
is there a disadvantage with going with the stiffer Figs bushing? And theirs will last longer, right?
Old 12-06-16, 01:06 PM
  #101
Daspyda
Daspyda's Avatar
Yes, it's enclosed in a bracket at the rear of the LCA. 48655 is the bushing, and 48652 is the bracket.
http://www.lexussouthatlantaparts.co...modelYear=2004
LudeAEM (12-06-16)
Old 12-06-16, 01:40 PM
  #102
Tom57
Tom57's Avatar
You will have noticeably stiffer shock absorption with polyurethane or neoprene LCA bushings. Check existing threads.
Old 12-15-16, 09:42 AM
  #103
BPLS430
BPLS430's Avatar
Just got back from getting mine replaced. I bought 2 Lexus OEM bushings on ebay for $125 and my local shop put them in for $150, a total of $275. My bushings were visibly cracked, but not a huge amount, but I was getting some clunking over rough spots of road and while going over some bumps. I need another longer drive to be sure, but it does seem like most if not all the clunking I was getting is gone.
I'd like to do the shocks, lower ball joints, sway bar bushings, tie rod ends eventually, but figured I'd do just the LCA bushings first to see how much of an impact they make on their own before going and spending big money on a lot of parts.
Old 01-09-17, 07:57 PM
  #104
FIGS
The Maker
FIGS's Avatar
That bushing housing is a real pain to break free. That is one reason why we just offer the complete bracket replacement complete with our progressive support bushing. The road feel is not uncomfortable and the impact on inner tire wear and braking stability is pronounced.
These bushings are direct fit.
http://shopfigs.com/v3/G2ISHP-FRLCA-...KT?search=%232
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 01-10-17, 08:48 AM
  #105
Daspyda
Daspyda's Avatar
Mike
Would you guys consider using the same bushing material that Lexus does as an alternative? Some people prefer OEM-like rides instead of the slightly stiffer experience your bushings provide.
Or, buying some OEM bushings and installing them into your brackets?
Quick Reply: Lower Control Arm Bushing Repair
