How to clean seatbelts
when i give the ls a good bath i take hot water with tide and a clean towel
dip towel in bucket with hot water and tide mixed into it give it a good rub do 6-10 inch at a time then have another clean and dry towel to dry the seat belt. this has been the best way for me to clean my headliner and rug and have a nice clean and nice smelling car
I have the ecru (off-white) interior and so dirt shows up quite well. My belts were pretty dirty and so I got the car detailed. The guy used a steam cleaner to clean the belts and they turned out wonderful.
I cleaned a set of dirty seatbelts once in a CRX I had. I rolled them out all the way (they normally won't be dirty beyond a certain point) and put a clamp on them to keep them from retracting. I then took a 2 gallon bucket with strong detergent and hot water, immersed the belt in the solution and scrubbed, then rinsed a couple of times. For the part that is so close to the mounting point that it wouldn't go into the bucket, I used a tooth brush for the cleaning/rinsing. After cleaning and rinsing I vacumed dry with a shop vac, then left them extended for a day or so to fully dry. The belt material cleans up very well and looked new afterwards.
+1 ^^^
Except I unbolted them at the base - rolled them outside, closed the door on them.
Now outside the car I had a helper extend them and used a pressure washer to blast out the dirt.
There are "seat belt cleaning" products out there. One is from PRO car beauty online
C-28 SEAT BELT CLEANER AND SPOT REMOVER.
But I suggest that you go to autopia.org and check their reviews or post your question on one of their forums.
