changing spark plug passenger's side???
I'm trying to change the spark plugs by myself.
I did the driver's side, and it was peace of cake. But, the other side (passenger side) has a black box blocked the way to reach the plugs. I tried to remove that box by removed one 10mm bolt holding the box down, and loosing the hose clamps one attached to the engine and the other to the filter box "I think". Anyway, I couldn't remove the end attached to the engine!!! its tough its hard plastic its strong!!!!
How does it removed? so I can finish the job. Otherwise, I will take to the mechanical to do the other side and see how he removes it for the future purposes.
If anyone knows how, please let me know??
Thanks,
Bassil
Thanks,
Bassil
Bassil,
All you have to do is use a bit more force to pull the intake hose off of the throttle body. Mine was tough too, but keep working at it wiggling it back and forth while pulling, it will come off. Once you pull it off the intake hose and black box lifts right out. It only has one 10mm bolt holding it down, which you've already removed. See the attached PDF diagram.
While you're at it, you may as well remove the throttle body and clean it good. Its only held on with 4 bolts. Remove those bolts and unclamp the hoses to pull the entire body off. Use throttle body cleaner to clean out all the gummy residue on the inside of it, then re-install it. Make sure you line up the gasket properly when bolting it back on.
With that piece removed, you'll have access to all 4 passenger side coils and plugs. There is no need to remove the battery for the plug farthest back. Just use a uni-joint and various extension rods and you can easily remove all of them with no problem.
Bassil,
Hi Bassil.........did you complete your spark plug change or was it too cold in your garage? lol.
What type & brand of plug did you use, if you don't mind sharing? Any more words of wisdom? I will be attempting a plug change sometime.....and also try to convince my gf to snap some pics (of the PLUGS!)
What type & brand of plug did you use, if you don't mind sharing? Any more words of wisdom? I will be attempting a plug change sometime.....and also try to convince my gf to snap some pics (of the PLUGS!)![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Tips?
Take as much plastic off of the engine (intake cover, both side covers) and the air inlet and box.
Use a spark plug socket, otherwise you will need to use a extendable magnet to pull the plugs out.
Have u-joint adapters available.
Use anti-seize.
Don't cross-thread the plugs when installing. I use a short (8") length of black fuel line over the spark plug top terminal to "start" the plug to avoid cross threading.
Don't over-tighten, but make sure you flatten the crush washer.
If you are using iridiums, don't try to gap them. Don't drop them, and chances are, the gap will be correct out of the box.
I did mine a couple of weeks ago, used NGK Iridium IX spark plugs. I purchased my LS with 57K miles on it, and I was changing what I assumed to be the original plugs.. which were NGK Iridiums.
Tips?
Use anti-seize.
Tips?
Use anti-seize.
Yesterday I bought 8 new Denso Iridium Power (IK20, #5304) on Ebay and it ended up costing less than $10/plug including shipping.
Thanks for the tips again, even though you let us ALLLLLL down. We were hoping for another play by play w/pictures, similar to your SWEET brake pad replacement w/pics.
Excellent advice Todd. Thank you. Not sure if you saw my posting but the dealer wanted $600 total for a plug change.
Thanks for the tips again, even though you let us ALLLLLL down. We were hoping for another play by play w/pictures, similar to your SWEET brake pad replacement w/pics.![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
I will bring the plugs along with incentive$, and you can provide the labor?
JK! I don't want to go wrenching on her while enroute on a trip!!!...although I AM stopping in one of those cities overnight...on Sunday the 18th.
Bassil,
Original plugs will be densos,SK20R11. I replaced my plugs and gave the TB a quick clean while I was there.
A spray of carby cleaner on a rag,and wipe all over the throttle plate and around the housing. My car has a bit over 60k Miles on it and the throttle was dirty,but not overly bad. I don't generally remove throttle bodies to clean them,most of the time you can get to one easily enough on the car.
Replacement plugs were NGK Iridiums, IFR6T11.
As for the TB gasket,it's reusable as long as you're very careful removing the TB. DO NOT separate the gasket from whichever side it sticks to (TB or manifold) as it'll be brittle and compression formed for a specific location. if it moves,it may not seal properly,and there's a good chance it'll break. When going back together,a SMEAR (not a wipe,a VERY thin layer) or gasket goo or O2 sensor-safe silicone across the face of the gasket will ensure a good seal.
Justin...
Justin...
