04 Lexus Ls 430 navigation system screen off
Hello guys i have an 04 Lexus Ls 430 with navigation system and sometimes the screen goes black and the a/c display temp. turns off, sometimes if i turn off the engines and back on it works again. When the screen is off I get a message in the screen that says "THE EXTERNAL SYSTEM IS NOT CONNECTED" have you guys had this problem before or know what to do with it? just bought the car and do not know what to do to it? I can't use any or the controls of the navigation system when the screen goes black,
Welcome to CL.
If it says that the external system is not connected, it could mean that there is a loose plug somewhere. Open the trunk and take a spare wheel cover off, then take out the passenger side cover and you'll see two boxes and two plugs. the box that's further away from you is an amplifier, the one that's closer to you (closer to taillights) is the DVD Navi unit with DVD map disk inside. Check the connection to both Navi unit and AMP since a navi in LS will not work without a stock amp. If both connections are secure go to a car electrician and let him check if the AMP is working properly, if not, you will need a new amp. It's expensive so look on ebay for a used unit. Hope this helps.
Welcome to CL.
thanks a lot
Thanks in advance.
hello i am having the same problem with my navigation on the same year and make that ya'll are having i took my car to a lexus dealership they put it on a diagnostic machine and determined that the ground wire was fried so i had them do the work and it is still saying the same thing now i'm really angry and i tried to get my money back but to no avale they are trying to tell me that i need a new navigation screen but it works perfectly fine but i keep getting the external system is not connected and i cant operate any buttons did you find out how to fix the problem maybe they should do a recall or something but please help me out
Has anyone gotten anywhere with this stupid problem yet?? It has been going on in my car (04 LS 430) for awhile now. I was talking with a friend about it and he thinks the stock amp is just for the sound...which works just fine for me. He didn't think there should be so many problems with the screen and everything turning on an off when it wants to because of the Nav system. He wonders if it is the screen unit itself.
The problems I am having sound just like everyone else's. The system has a mind of its own.
Thanks for any imput you can give.
Jennifer
Jennifer
Is this issue primarily with the Gen 4 unit or earlier units as well?
One of the dealers in Minnesota said they can do an update with the Navigation cd...he recommended waiting for the generation 10 that will be coming out the end of September. That just sounds like to easy of a fix...has anyone heard of this one yet?
Navigation out
Have the same problem. Dealer suggested a refurbished unit. Has anyone tried this. Has anyone has any support on getting Lexus to cover this obvious defect. Given you have no manual alternative to operate AC and several other features, this should be covered.
My first contribution
Guys I am new to the forum having just bought my 2003 LS. I call it my "anti-Prius" because that is the car I had before the Lexus.
Anyhow I had this exact same problem on my 2004 Prius. The Lexus and the Prius share a few parts or at least share similar technology, including I believe the nav screens. There was a known problem with the early (read 2004) Prius nav screens and apparently they replaced many of them under a "soft recall". Mine finally broke and I was out of warranty and of course pissed to learn it was a known problem and the dealers only suggestion was a replacement screen. Then I came across a Prius guru who also was an electronics wizard. He researched the problem and came up with a fix, it arises due to a bad solder joint between two sections of the screen. Here is the good news. He started a service to fix them!
You can send him your screen, it is a minor hassle to get it out, but not too bad and about 8 days later I had it back working 100 percent. He even pointed out (at least on the Prius) that the car would operate sans screen and the auto heating system would as well you just would lose the indication of what exactly was going on real time. I operated my car that way while my screen was out for repair. I think the whole effort cost me $300.
Here is a link to his operation.
http://www.autobeyours.com/Ebay%20MFD%20listing.htm
You will note that the repair service indicates that it also applies to highlanders and land cruisers but I am willing to bet that the Lexus screen is the same "fujitso ten" manufacturer with the exact same issue. Looks like the price went up to $325 but still a bargain compared to $4500 and trust me it fixed the issue.
Good luck. BTW: when this was happening to my Prius it started just occassionally and then became an almost constant issue, so this may get worse for those of you having the issue.
