Identifying marks of an Ultra Luxury?
What are the traits that the UL has over other trim models?
- 01-03 has the backup sensors on the bumper
- rear arm rest has AC and radio controls
- 01-03 has switches in the center console for ride height
What do the 04-06's have in terms of identifying marks? I can spot the 01-03 but don't know about the 04-06.
Also what other trim model has factory air suspension? Custom Luxury? Does it have the same buttons on the center console for ride height?
you will not find another trim other than UL with the factory air susp, and check the sticky for more info on how to determine if its a UL or not,, you pretty much covered it, and 01-03 / 04-06 are just about identical in terms of identifying a UL over non UL. .... side rear curtains, suqare plastic grill where the L is, perfectly symmetrical front bumper...
Looks like the 2001 Custom Luxury has air suspension, while the 02-06 only allows it on the UL.
http://www.cars.com/go/crp/research....tionsAndExtras
Thanks!!
Thanks!!
Forum Administrator
Search and you'll find plenty of discussions on this topic Here are just a couple
https://www.clublexus.com/forums/ls4...y-package.html
https://www.clublexus.com/forums/ls4...430-ultra.html
One way to tell that is not often mentioned it to look at the front of the trunk (or a pic that shows the trunk clearly). In non-UL cars, the trunk extends all the way to the back of the seat and the hump in the floor and pass-through are visible. In UL cars, the front bulkhead of the trunk is just past the start of the wheelwells and you can't see the hump in the floor or the (non-existant) pass-through.
Thanks!!
Thanks!!
I BELIEVE THIS 01 NON UL W/ AIR SUSP TO BE A MISTAKE or typo...
if you come across one can you please let us all know.
If you are referring to the clear plastic piece in front of the "L" emblem on the front grill, this does not signify the car is an UL. The Custom Luxury version also came with the plastic grill insert (part of the Pre-collision System - PCS).
I have a very early 04 UL which came out before the PCS was included. The plastic grill insert was a part of the PCS. My UL does not have the plastic grill insert.
Just from pictures, the easiest is the trunk like Caddy-man is describing. Most pictures online don't have the rear center armrest down so you can see, also the views some times are of the front doors, etc. so you don't see the full center console. If you're just looking from outside at the four corners, you can't tell if UL or CL. Even if lowered, could be just a CL dropped.
when i first read this thread i was thinking you were asking how to tell if a car was a UL by it just driving by next to you in traffic for example... to me this is the hardest possible way to tell cuz unless they have their rear sun shades up its very very hard to tell. but one of my neighbors has an 01-03 UL and i have never once seen him have his sun shades up.
my bad i thought the pcs thing was only on a UL i have never seen one on a non UL in the 04-06 range yet, but like someone said i have seen some UL's that didn't have the square plastic thing.
Per the sales brochure, laser adaptive cruise control was standard on the CL and UL. This did not have the square plastic thing. Radar adaptive cruise control with PCS was an option on CL and UL. This had the square plastic thing.
I suspect the radar was required to get a faster, more accurate reading of the distance and closing speed in order to activate the pre-collision system.
1 - Look at the pics of the front of the car and identify if there are headlamp washer covers on the top of the bumper. There are usually at least two pics of the front of the car, a quarter view and a straight-on view. When the headlamp washers are present, the car is a CL or UL.
2 - Look at pics of the center stack for additional switches in front of the shifter. These switches are only present on a UL.
3 - If the above switches aren't clearly visible, look for a pic of the back seat with the armrest folded down and check for the UL controls on the armrest.
4 - Look for a pic of the back seat and search for the manual pull for the side shade at the inside bottom of the rear door window. Again, the side shades are only present on a UL.
5 - Look for a pic of the trunk and determine how far forward it extends. If the forward bulkhead of the trunk is at the back of the wheelwells it is a UL. If the forward bulkhead is at the back seat, the pass through is visible, and/or a floor bump on the center / right side is visible, it is not a UL.
Also remember that the only interior colors on CL and UL units are black, ecru, and saddle. No gray or cashmere. Ignore the color printed in the ad because sellers screw this up all the time - especially ecru, cashmere, and saddle. Differences between these 3:
- Cashmere is beige and the seat color matches the carpet. Depending on lighting, it can look dark or light.
- Ecru is off-white and the seat color is somewhat lighter than the carpet.
- Saddle has brown/orange leather seats and all carpets and other leather is black. This is a rare offering and usually only found on black and a few white or (supposedly) flint mica cars.
Yes, I have a problem with spouting too much detail.
Search brother...
Anyway, look around, they're out there, just not in great numbers.
