future buyer, not impressed with HID :(
tested a stock 2001 UL package, nice silver with black/red wood inside.
Really, I am not impressed with the HID headlight.
It looked nice from the outside, bright and white but it was bad when driving....I had to check the headlight switch a couple times wondering if the light was on.
Going back to my Camry after the test drive, I was like OMG, my Camry has better headlight, seriously.
Current owners, what do you think about the HID on your LS?
Is it the color or the actual output that you are not satisfied with? I have an 05 SC and an 01 LS and the only difference is that the 05 has a "bluer" output. The reason for this is most likely the color temperature that the bulb emits. The LS uses 4300K (whitish) while the SC uses a 6000K (bluish). My 08 Avalon and the LS seem to have the same color temperature at 4300K and I prefer the bluer tint (6000K); but I'm not compelled enough to change out my headlight bulbs. When they break, then I'll change em. Just a suggestion but you can change out your bulbs. (It was hard doing it on my SC, but definitely worth it)
HIDs are very sensitive to aim because they have a distinct horizontal cutoff to help prevent the light from blinding oncoming drivers. The vertical aim may need to be adjusted. Also, if one has never driven a car with this headlight design, it can appear that there is something wrong with the lighting because of the sudden cutoff.
Something was definitely wrong with the HIDs on the vehicle you tested. The LS430 projectors are insanely good. In my 05 it's like a solid 160 degree light blast in front of me when my lights are on. I'd describe it as being ridiculously good.
Having driven the 05\06 and later model change Camry there is no comparison - the LS smokes those cars headlights. I've driven a lot of other late model cars as well (Lexus, Infiniti, Volvo, etc) and I've never found anything that comes even close to the LS headlights.
Go and test drive another vehicle - I'm sure you'll be pleasantly surprised. You'll then be really grateful you didn't buy the car you just tested as well.
About the only thing I don't like on my LS is the lights, the HID light in 06 LS are OK - but don't kid yourselves, there are lots better lighst available. For example, the LS lights are nowhere near as good as the ones I had on my 1999 RL. The HID on the RL were world class good lights. I did not realize how good the HID were on the RL until I got the LS and was significantly disappointed.
IN the LS the HID do cast a wide beam in case you want to see whats at your extreme left or right, but I would prefer better lighting upfront ahead of me. The beam cut off with the LS is too harsh. It also does not provide light for approaching street signs on dark roads. In addition the auto adjust lights are bouncing up and down trying to adjust and with the cutoff being so harsh its just lame and distracting at best. btw- I had my lights dealer adjusted per Lexus specs and they are still disappointing. Just my .02 worth.
LOL I guess I just have good eyesight at night. I've had the 2 LS, the GX, BMW Bi-Xenon, MB Xenon, Audi whatever it's called, and I don't notice $.10 worth of difference between any of those and the original headlights in my '95 Supra. I can see perfectly well with any of them.
Now, several of the domestics have some $uck-a$$ headlights.
I6turbo - sounds like you have better experience then me with a wider range of HID cars. Maybe something is slightly messed up with my lights - I'll have Lexus check them again at the next service.
I drove my friend's TL and it is much better (at least I didn't have to check the headlight switch)
It's possible something is not right with the LS I tested. Probably test some others to see how it goes
thanks guys
My 2002 LS has reflector HIDs similar to or the same as the 2001 LS. I think my lights are awesome, they light up everything in front of me very well. If I recall correctly, they are 4300k. High-beams on the highway are quite bright and wide, in my opinion.
I believe the projector HIDs were fitted in 2004+ models.
