Another offset fitment q?? 19x9.5 et27 245/40/19
Will I rub? or bigger questions is will I even clear in the rear? I have different #'s going in the front.. Please help ease my mind while I wait... Thanks in advance fellas.. - Bryan 02 ls430 if it matters... Thanks again.
I have on some Wald wheles with these specs and no rubbing issues.
Hope this helps.
Fronts = 19x8.5 +30 offset
Tires Bridgestone RE050A 225/45/19
Tire Pressure 45psi
Rears = 19x9.5 +36 offset
Tires Bridgestone RE050A 245/40/19
Tire Pressure 43psi
DanozLS430
Hope this helps.
Tire Pressure 45psi
Tire Pressure 43psi
DanozLS430
Thanks for the reply, i am slightly lowwered with factory ul air and will have the youzealand Ss pro kit on the way so I hope I can slightly tuck tires with no issues. Ahaha many views but just your reply. it seems many people like to keep there #'s hush hush.. Anyway, Thanks again for the reply 9mm doesn't seem much of a difference so I think I can relax..
bighitbike
06-11-07 10:23 PM
jbbnet
Wheels, Tires & Brakes Forum
02-07-03 12:29 AM
