05 Wipers Banging on Hi
The wipers make no noise on low speed but when they switch to hi there is a banging sound at about the middle of the windshield when they go all the way down. I just checked and the drivers wiper is actually hitting the rubber windshield seal. There seems to be a lot of slack in the blades and drive mechanism. Is there an adjustment to the arms that will change the range of motion or a bushing that wears causing the slack and an increase in sweep?
Update
Well the noise is actually coming from the drivers wiper pivot hitting the passenger arm on full down stroke. The paint is worn off of the drivers side wiper pivot, that section that the two drivers side arms attach. Maybe it needs to be adjusted up a bit.
