blinking navi locator
Interestingly enough, they both use the same MAP version/disk! The part # for the disk is the same.
My take on that would be the maps would look identical (on an 01 and 02) on the screen, but the electronics/cpu/headunit/drive/whatever you want to call the brains in the trunk, is different.
I am sure it's not supposed to blink. It's also not supposed to lose signal often, although that is dependent all on WHERE you're driving it. As Jim already asked, I was going to ask you if you have any tint on the windows but you already replied, no.
Do you ever lose signal in a wide open area, standing still? Do you always lose signal in the same area or random areas when you lose signal? Has the car ever had physical or water damage in the trunk area? If the 01 is like the 05, the nav electronics are on the passenger side of the trunk, under a panel.
If I were you, I'd spend about 30 minutes and gain access to the nav unit, then, with the car not on, disconnect and reconnect all connectors/harnesses/plugs several times.
Also, do you know for a fact the nav antenna is on the roof? I thought the antenna was in the dash. Is your dashboard cluttered by anything by chance? (notebooks, clipboards, etc?)
to: LS430inDE
I believe I do lose signal in open areas, where the GPS logo will disappear, and then randomly appear again. I do lose signal when I don't have a clear view of the sky, but that's normal. I also lose it in open areas, which I can't explain. I checked the gps in the trunk. Everything looked brand new, no water damage. I don't really know where the gps antenna is. I thought it was on the roof, but I could be mistaken. Either way, my dash is completely clear, with nothing on it, except the XM receiver above the right front tweeter.
to: JimsGX
I don't think it's an option. I went to that screen, played around in there as best I could. There's a tab that's called Location. I press it and it takes you to the map and shows that I'm in DC, then takes me back to my location. There's another option, that just shows the latitude and longitude, and nothing else. I may not be doing something right to correct the problem in there, however, I'm pretty sure the blinking is not an option but a message that says something is wrong.
to: jayclapp
I'm planning on taking it to the Lexus dealer to have them diagnose the problem. I can just hear it now: "Oh, this problem. All you need is a new nav drive in the trunk. That will just cost you $2K." I just hate it when they charge you for an hour of labor, and don't really tell you anything except what you already knew, like "there's definitely a problem". I already knew that, that's why I'm here!
Did you try the recalibrate option? I think there's a way to reboot these things too, so its wipes out everything stored and starts from scratch. Simply turning the car off doesn't accomplish this.
I haven't tried that. I don't really want to unplug the drive in the trunk. Is there a way to do that in the hidden menu? There's a way to dump old info, but I don't know what that does. Any ideas?
Do you have the original Navigation booklet that came with the car when it was new? The instructions would be in there. Alternatively, if you login to the "My Lexus" portion of Lexus.com, the Navigation Manual will be available on there for your 2001...
Here's a link to the login page: https://secure.drivers.lexus.com/lexusdrivers/home
You'll need to register and have your VIN handy. Once in, you can look up all the service history for your car (that was performed at a Lexus dealer). Plus have access to all the manuals for your 2001...
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
http://www.youtube.com/watch?v=8xav7KLfO2I
look at 3:21 it shows it in the original promotional video. mine is the same way, i guess its supposed to do that.
If you guys say it's normal that the icon blinks like that, then I guess that IS normal..but that just doesn't seem intuitative nor normal to my eyes.
A blinking indicator, to me, is an attempt to draw an extra-ordinary amount of attention to a situation.
I agree- Im assuming they changed it in the later model years because they felt that way too. It would drive me nuts- no reason for anything blink unless there is a need to call attention to itself. bad design IMHO
Geez! Where have you been all this time then!? ![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
I have an 05 w/nav and I don't think I've ever seen the icon blink...
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
