red oily fluid leak
red oily fluid leak
I live in AZ and when it starts to get hot i end up with fluid on my gargae floor. The fluid is red and oily. It appears to be comming from the front middle of the engine compartment. It only happens when it is hot above 80. Is it coolant over flow?
the dip stick was out slightly. It is comming from the very front of the car. I thought it was Coolant,becasue it only leaks when it get warms
Define oily. Transmission fluid and the Toyota coolant are both reddish in color. The transmission fluid being thicker, more viscious, while the coolant more "watery." If you just feel the coolant, it might feel somewhat "oily."
If you have '04-'06 LS, it has the World Standard (WS) sealed trans and there is no dipstick to check the fluid level. Easy to see if coolant, just open the radiator when cold and check the reservior and check levels.
There are only 3 red fluids in the car: transmission fluid (Type T-IV for 01-03, WS for 04-06), coolant (red or orange, depending on if your car is a 01-03 (long life) or 04-06 (super long life)), and power steering fluid (OEM is kind of translucent yellow, replacement is dextron II/III ATF). If it's coolant, it's from the overflow tank. The fluid expands when the engine is hot, plus the radiator cap valve opens to relieve the pressure and allows the fluid to flow into the overflow tank. When the coolant in the engine cools, it sucks some of the fluid back in, so you'll see the coolant level in the bottle rise when hot, drop when cool. It should stabilize between the high and low levels. If it continues to drop even after you add more coolant, something is wrong. PS: only use toyota long life (red, for 80-03) or super long life (04-10) vehicles. The red should be mixed w/ 50-50 distilled water. Do not use tap water (most dealers do), and do not mix coolant colors (clogs the radiator over time despite dealers telling you it's ok).
This may be totally old school...like when asbestos was used for fireproofing..lol, but you can also TASTE what it is. Just take your fingertip and barely touch the fluid. Put it to your tongue. Tranny fluid will most likely taste like it's a little "burned"...while coolant will taste "sweet". That sweet taste is also why some animals mistakenly lap up spilled/discarded antifreeze/coolant on the ground!!!!
I am not kidding with this.
I don't know your family history/allergy records/etc, so maybe you should just take my advice with a grain of salt. lol.
I say try it.........but do it at your own risk. <---my disclaimer
ps....not sure what power steering fluid tastes like. Maybe JimChow does? lol
3UZ-FEEEE
If its from the front of the car, its most likely coolant (could be power steering line since it goes out there to cool) but since it only happens on warmer days most likely your coolant.
Check to see if the reserve tank cover is sealed.
year2000
04-10-18 09:21 PM
