How Do I Remove Interior Wood Trim Pieces to Install Console Ashtray Alternative?
That console box is very welcome for my wife. She wants quick access to tissues and can't lean forward to reach the slide out drawer on the center stack. In the Lincoln, the grab handle on the door had a solid bottom, so that was her tissue stash. As someone recently noted, the door pull in the LS430 is a bottomless pit.
Why does the wood trim piece on the ashtray lid have to be changed? I ask because the wood trim mine has is uncommon so it wouldn't be a difference in shading, it 2oulr be an entirely different color
The console box comes with a lid. If you don't think the pattern or color matches, you can remove it and install the lid from the cigarette box you have just removed.
Perfect, I just found out the fuse was blown so I bought a several of each amp and go through the fuse boxes...maybe some stuff like the hazard lights will start working again. I'm about to begin tackling problems now that I have the motors.
Buy this kit Install Bay 4 Pieces Scraper Kit I watched a guy work on Lexus interior with this kit is awesome. Keeps you form breaking the plastic clips below the surface. make sure you know where the clips are below he surface so you do not break them
topperdogg
04-15-18 03:09 PM
