Red Caution triangle
red caution triangle showing in display and message is Maintenance required. I just purchased this Lexus Certified LS 430 just a few months ago and the dealership said that the 50,000 mile maintenance has been done. Is there something that the dealership forgot to reset or must I redo the maintenance schedule in Navigation. Thanks for the help!
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
red caution triangle showing in display and message is Maintenance required. I just purchased this Lexus Certified LS 430 just a few months ago and the dealership said that the 50,000 mile maintenance has been done. Is there something that the dealership forgot to reset or must I redo the maintenance schedule in Navigation. Thanks for the help!![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
The maintenance intervals in the navigation are separate from the indicator on the cluster.
This will reset the triangle indicator on the cluster.
https://www.clublexus.com/forums/4562379-post2.html
Read page 96, 462 of the owner manual. On page 95 "mileage reset" will show you how to reset after you perform the maintenance.
1. Push the "ODO/TRIP" button to chnage the display to blank.
2. Turn the ignition switch off.
3. Turn the ignition switch to "ON" the the trip meter "RESET" button held down.
4. Keep pushing the "RESET" button for longer than 5 seconds after the ignition is turned on.
After the above operation, the master warning light comes on, a warning tone sounds and the above message appears to inform you that the engine oil maintenance data has been reset.
Thanks so very much Grand LS 4! Mine recently came on while on a trip (as well as the low tire sensor). Every time I take this car on a trip the dash lights up. This time I was able to reset the low tire warning myself. (Tire pressure was fine) Last time it required a trip to the dealership to finally get it turned off. You saved me form an unnecessary trip to Sewell for the maintenance light.
