Cost for Dealer to Repair Steering Column Retract / Extend?
I noticed that my steering column extend / retract is no longer working. I hear it clicking, but it doesn't move. It goes up and down OK, though. (I have the auto-retract disabled, so it's no big deal that this doesn't work.) I will probably have it fixed on my next service visit. Any ideas how much this will run me?
It should cost you nothing. There is a TSB out on the steering columns on the car (at least my year 03). just had mine done two weeks ago. I can get you the TSB number if you like but it was titled "Universal joint and telescopic slider support".
honeygee2, can you give me more info on the TSB for the telescoping steering wheel? I have a 2003 LS with the same problem and while at the dealer recently they said there was no warranty coverage for it.
Thanks
Thanks
Reading right off the repair order dated 03/18/2010....
Cause. Insufficent torsional strength of the telescopic steering cable.
Correction. Replace steering shaft universal joint and telescopic slider support per TSB#ST001-04
That's the info. My car is under CPO but I believe a TSB should cover the repair.
The steering column TSB is for a creaking noise when wheel tilts up/down when key is put in or out of ignition. The following is my old post here from when I had that issue with my '04 LS. (I am told it will only be performed at no cost while vehicle is still under warranty.)
Walt
Took my '04 to Lexus today regarding creaking noise when steering wheel raises and lowers while turning key on/off. They performed TSB on that very problem (which was mentioned on this forum in 2004).
It includes installing a part ( part #45767-50010), and was done quickly.
STEERING COLUMN NOISE - ST001-04
Number: ST001-04
Bulletin Date: 1/7/2004
Applicable VIN Range: ’02 – ’04 LS 430 JTHBN30F#20059627 to JTHBN36F040141419
Summary: Some LS 400 and LS 430 vehicles may experience steering column noise due to insufficient torsional strength of the telescopic steering column cable. The cable has been replaced with a universal joint to prevent steering column noise.
Walt
Number: ST001-04
I don't think TSBs are performed for free if the car is outside of warranty period or miles. TSBs (technical service bulletin) are not recalls, they are published as tip sheets and guides for Lexus mechanics (and others) to use in troubleshooting and making repairs to common problems.
This issue makes me want to disable my auto-retract mode on my next visit. Hey Caddy did you disable it at the dealer or your car came like that? if you went to the dealer.....how much was it?
FWIW, I recently (about 1 month ago) started experiencing serious problems with the steering column not coming down when I started the car. It was acting crazy- sometimes working, but most times, not. It turned out (and I mentioned this in a previous post at the time) that it was all due to a bad cell in my battery. The car, at times, sounded a little weak when cranking, but always started up. Then one day, it was dead. When I was having the new battery installed, I mentioned the fact that the steering wheel had been acting crazy - with the retraction thing, the guy said that was a common-type symptom when a battery has a flaky/bad cell.
Since replacing the battery that day, I have NEVER had any problem with the steering column again. It ALSO fixed my flaky mirror problems - they had each randomly decided, on their own, when they would fold in or out for me.
Amazing - all because of a bad battery cell.
Walt
Walt
Walt
Walt
caddyowner, did you do anything to resolve your problem?
[Is this still the case? No further problems with the steering wheel and mirrors after the battery replacement?]
Happy to say "Yes!"
It has now been more than a month since my battery replacement and I have not had even 1 more incident with EITHER my mirrors or steering wheel.
At that time (March & before) I had problems with either my steering wheel, one mirror, or both mirrors every single day.
It's incredible - all mirror & steering wheel problems gone! I can't explain it, but the guy was right. Whodathunkit - a bad battery cell.
Walt
Happy to say "Yes!"
Walt
PS: I learned about the steering wheel retracting motors going bad on all Toyotas/Lexus that had them, so I had mine disabled as soon as I took delivery. The motors will still work when you use your memory seats feature. Ditto for the tilt down side view mirrors/folding side-view mirrors. Since every car I've owned before the LX/LS didn't have these features, I learn to live without them and only use them when I really need to, like when parallel parking in a tight spot, not when backing out of the garage every morning. The mirrors are like $1600 each.
I may have to get my steering wheel retract turned off also. I do keep the swing in mirror feature turned off as I never park very close to other cars. As far as tilt down auto adjustment for reverse, the mirrors don't tilt if the mirror switch is set to middle position instead of to R or L so I can leave it in middle "disable" this function. I almost never parallel park in Dallas area anyway, and when have to parallel park, learning to drive and park in Chicago, where I parked that way multiple times a day for years, makes parallel parking a trivial exercise.
Bob04
02-05-15 07:57 AM
