Does leaving an iPod hooked up to SL2i run down the battery?
Just had SL2i installed. I left the iPod plugged into the car, and didn't drive the car for a few days, and the battery was dead! I called the lexus dealership that installed the Vais Tech, and they said that if the key was off then the iPod would NOT drain the battery, ... but something had too and thats the only thing that was new on the car. Everything else is completely stock. Also had the charging system tested and it's fine.
Given the extremely low current draw (500mA), you should be able to run an ipod with a fully charged 12v auto battery for about 2-3 months.
I can't believe the SL2i and/or iPod is your problem.
