Maintenance at 14k miles? What to do...
As some of you know, I recently picked up an '02 LS430 with only 14k miles. From talking to the previous owner, the only thing done was oil changes every 2-3k.
I am not in the normal mode of maintenance. Usually it is mileage or time. In my case it is mostly time. It seems to me that I am now faced with a lot of fluid changes (other than the required oil and filter). And, technically speaking, the timing belt should be replaced because it is older than 6 years (72 months). Oh, I don't want to go thru that again just yet (just got done doing a TB/WP last fall with my 98 LS).
What to do to catch up on maintenance?
-complete coolant system drain and refill
-brake fluid flush
-differential fluid change
-tranny fluid change (2 qt drain and fill)
-filters (air and cabin)
-power steering flush
Seem about right? Anything other than what is in the manual?
-brake fluid flush
I think you are spot-on except for the power steering flush. I suppose you could drain and refill the PS fluid but I would not introduce any flushing chemicals into the system. It's probably fine as it is; I've never seen PS fluid replacement in an Lexus maintenance schedule.
Your air cleaner is probably fine -- age isn't going to affect it. The cabin filter could be OK too - pull it and inspect it.
Actually, the trans and diff fluid are probably fine too -- but replacing those fluids is super cheap ... I'd probably do it since I'm sort of obsessive about car maintenance.
If your tires are original, replace them ASAP. They could be nearly nine years old by now.
Jim! you found me!
Actually, I have already replaced the tires. The original being 8 yrs old were in good looking shape (not dry rotted) but one (or more) of them had a persistent flat spot on it that I could not live with. Apparently, the car had been setting so long that it messed them up.
As concerns the fluid...yes, I agree that most are cheap enough that I will probably just drain and refill. Thats mainly what I mean with "flush". I also do not like to introduce a chemical in there to loosen things up. Just inviting trouble.
The TB is a tough decision. Beyond the time but way below the mileage. I will have to think on that one a while longer. My 98 was nearly 12 years old when I changed it and still looked fairly good so I know the time parameter is very conservative.
Speaking of being obsessive, my son wants to take a picture of me standing next to my LS and entitle it simply: "Obsessed". Does it show?!
I had the same problem. I bought a 2003 LS in January with only 18,500 miles on it. The car was like it was in a time capsule, always garaged and in near perfect condition. I ended up replacing all the fluids with the exception of the power steering fluid.
I also replaced the timing belt, but not the water pump. The old belt looked like new but with this being an interference engine, I didn't want to take any chances. The Lexus mechanic said he had seen some belts that looked terrible with low mileage and some that looked fine.
Cheap money to pay for peace of mind.
I would not replace an 02 timing belt until 2012 if it has super low miles (less than 30k) and had been in a mild climate or in storage.
I think the key to me is what do the external belts and hoses look like on that car? If they are uncracked and like new, you should OK on the TB , but if the belts and hoses in the engine bay look old and oxidized, then its time to change the TB on the car now.
Slummin on CL? I thought it was an upgrade! I feel the love here.
As I lay there under the car staring up in wide-eyed Lex wonderment and wiping the dust off the hoses and cross-members....(anybody else do that? I clean the bottom of the engine while waiting for that last drop of oil)..I marvel at how nice everything looked and how incredibly easy the oil filter is to get to.
This LS430 engine bay is wide open compared to the LS400. NICE. NICE. NICE. Need I say it thrice? YES!
Have a look:
As I lay there under the car staring up in wide-eyed Lex wonderment and wiping the dust off the hoses and cross-members....(anybody else do that? I clean the bottom of the engine while waiting for that last drop of oil)..I marvel at how nice everything looked and how incredibly easy the oil filter is to get to.This LS430 engine bay is wide open...
However, the LS's (at least 04-06's), have a black plastic covering over the entire underside of the engine, not allowing you access to ANYTHING unless you remove parts of the plastic shroud/covering.
Even just removing the oil filter, you must remove 2 screws then fold back the black plastic "flap" to gain access to the oil filter.
Mind you, I'm not complaining. I'm sure this protective covering helps in the aerodynamics and helps prevent buffeting of the air, etc, on the underbelly, but you never mentioned removing this cover? I have THOUGHT about removing the cover to observe (preparing to be in awe, as you described), but thought the trouble was more hassle than it was worth...just to be in awe.
Did you remove this covering completely (about a dozen screws) or does your LS not have it installed at all? (It appears it's absent in your pic.)
You are right, I did not mention that I completely removed the under engine cover but I did. Just to clarify... this is not a tutorial on oil changing, just a comment. Yeah, removing the entire cover is somewhat of a pain but I will tell you what (what? ), that cover does more than aerodynamics. It helps to keep the underneath of the engine clean. And I really, really like that fact. I have to drive in some pretty nasty weather conditions (salt on the road), and the less of that gunk getting into the engine compartment the better.
So, I will gladly wrestle with the cover rather than leave it off. I take it completely off every oil change (about every 6 months) so that I can do a thorough inspection of components.
plunger
GX - 1st Gen (2003-2009)
03-31-12 12:15 PM
