02 LS430 Power door lock problem
My front passenger door lock does not lock when I put the car into drive. If I lock it manually it won't unlock when I turn off the engine. Any ideas on how to resolve this problem?
I'm getting mine fixed on Wednesday, same door/side. It's the motor most likely, mine is. It's a $5 dollar part but a costly repair. I purchased an extended warranty so it's covered, but if was not, I'd probably ignore it.
Thanks for your reply. I just called a local shop that specializes in Lexus repairs. He said it's probably the door lock actuator. Replacing with a new one is $600. They can rebuild the existing one for $300. I guess I can live with the problem!
Passenger door lock failure on 2002 LS 430
Mine just failed too.... 2002 on the passenger door... noticed it was not beeping when I locked it.... Anyone attempt to replace the actuator themselves????
jamesrawr
06-05-13 08:17 AM
