PCS glass in front of emblem
Yes, the square piece is a raydome for the PCS millimeter-wave radar. It's not just a piece of plastic, but made of a special material that allows the RF at that specific frequency pass through. The raydome protects the radar electronics from the elements while allowing RF to pass through. If you remove it, the PCS will likely fail due to weather=$$$$.
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
I looked at the back of it and was wondering if there was anything special about it since it didn't look clear and was "painted"
would believe they had tested the need for it before building them special,, if it would have worked fine with the regular emblem we all would have the same grill,, if you do not use it give a try but my $$$ says you will have issues,,
Derry
Derry
NormandyIS
02-13-13 11:55 AM
