2001 LS430 UL Steering Column Rattle
Old 10-06-10, 07:57 AM
Vpanin
Vpanin's Avatar
Originally Posted by DDLexus
Ha! My telescoping motor went bad, so I bought the whole steering column from a "recycle parts dealer". I found that it was cheaper to buy from a wrecking yard than buy a new part from the dealer. I'll probably list the rack on eBay eventually, for now it sits in the garage
What was you mileage when it went bad???? and do you have it on auto tilt away?
Old 10-06-10, 08:57 AM
DDLexus
DDLexus's Avatar
it went bad around 60k miles. I think the reason for the failure was that i used the "magic" trick of extending it beyond the factory extended length. You know, tapping the button 8x and it extends another 1/2 inch. I supposed that is what caused the failure. I posted some photos of the ordeal (lower dash removed) on another thread.
When it was going bad, the steering column never rattled or made noises when i drove. It just slowly started to have trouble extending and retracting when the car was started or turned off.
Old 10-06-10, 09:55 AM
Vpanin
Vpanin's Avatar
thats right......i saw that thread. Im about to turn off my auto retract.....these tilt/telescoping motors look like trouble
Old 08-11-16, 01:04 AM
Owczar
Owczar's Avatar
Has anyone solved this problem? I have similar issue.
Old 08-11-16, 11:51 AM
RA40
Super Moderator
RA40's Avatar
This may be of some help:
https://www.clublexus.com/forums/ls-...-solution.html
Old 06-07-19, 06:09 AM
weldthedif
weldthedif's Avatar
I know this is an old thread, but did anyone ever find a resolution. I was reading somewhere else about some metal bushings that may need to be replaced, but the info was very limited.
Old 06-08-19, 05:45 AM
RushNatU
RushNatU's Avatar
I have had this problem on the past three LS I have owned. It only happens with lower profile tires running over rough concrete. Nobody seems to have found a real solution yet.
Old 07-13-19, 12:37 PM
400fanboy
400fanboy's Avatar
Take a look at service bulletin ST001-04
Universal joint replacement in the steering column.
I'm about to do this to my 98 LS400. Bulletin includes my car in this range.
See this thread for my documentation + audio recording:
https://www.clublexus.com/forums/ls-...-bushings.html
Posting this here to provide future reference to others.
maximussp
03-05-24 12:29 PM
destro888
RX - 4th Gen (2016-2022)
09-10-18 07:09 AM
blksolara
07-09-15 03:26 PM
general98
07-06-09 08:24 AM
caha14
GX - 1st Gen (2003-2009)
16
05-12-05 06:25 PM
Quick Reply: 2001 LS430 UL Steering Column Rattle
