01 LS430 UL Factory ML Nav system audio integration
Whats the best method to integrate aftermarket amplifiers and speakers to the factory ML Nav system? I know all the audio/A/C controls are part of the ML Nav system so I would probably leave that alone and add to it with aftermarket amps and speakers. Right now Ive heard the Rockford Fosgate 3Sixty.2 and AudioControl DQL-8 are the way to go. But was hoping someone with more experience could chime in. Also Im assuming there is no way to supply the stock nav with a video signal?
Thanks
Thanks
Thanks
Thanks
JL CLEANSWEEP. Problem solved
Thanks
Thanks
a co worker of mine has a nissan murano, he would have lost a/c control if he installed an aftermarket head unit.
its easy i did it not an issue navi and a/c still work.no beat sonic or kit need unless doing a double din. i just made a new harness from the after market radio to the output of the ml amp wires. thats it.
![](http://i214.photobucket.com/albums/cc266/tubbyg35/6f7dc640.jpg)
![](http://i214.photobucket.com/albums/cc266/tubbyg35/bf5d4f32.jpg)
just don't use the steering controls. to gain i pod, dvd and better sounding system is worth not using the steering controls. (just in case it gets crazy like that other thread about replacing the ml system. my stereo sounds better to me and i really don't care what ml purest think.)
i have an 04 LS430 with ML Navi,i would like to bypass Navi+play music/vid from ipod+ DvD player+add 2 12"subs and amp.
can all of that be done WITHOUT changing the 6disc cd changer??
if so what do i need?? link or website please??
thanks
thanks
I like the set up. Can you provide more information on where to get it and how it was done? Thanks.
HiloDB1
06-29-10 07:03 PM
bostonsnow
02-03-08 01:21 PM
