air filter warning light
I have taken my 05 ls 430 to the toyota dealer 3 times to remove the air filter warning light when the car starts. I have tried using the touch screen to eliminate it ans so have they, do you have any ideas?
Probably same warning I get. It says to change the cabin air filter. I have not changed mine yet so not sure if that is how easy it is to fix. I thought I read the filter is in the glove box and is easy to change.
I think the warning light is just a simple mileage based reminder. I don't think it has any sensors in or around the air filter or HVAC system.
Air filter warning light
You cannot turn it off with the maintenance reminders. Read the owners manual - you have to push and hold the A/C "Off" button for 4 seconds. That will make the warning go away.
