Old 12-16-14, 11:41 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
Print Wikipost
HOW TO: LS430 Interior/Exterior Lights/LED w/Pics & part#s
Old 02-17-16, 08:11 AM
  #151
ryanSC300lover
ryanSC300lover's Avatar
Are the 2001 and 2004-2006 front parking light the same?
It's a small bulb on the upper part of the high beam area
It's nasty yellow when at night the xenon are on
I would like to replace it to match the xenon
I don't care about drl being yellow (that's fine)
Old 03-15-16, 03:19 AM
  #152
drab4
drab4's Avatar
Having trouble prising down those mirror lights. I have interior removal tools and credit cards, I can get in tools either side, but it's just not coming down any further than a mm or so! I also don't want to use too much force and crack or break something as very expensive to replace.... - any tips!?
Old 05-08-16, 07:54 AM
  #153
GaborL
GaborL's Avatar
Originally Posted by BIGGZ
good right up bro!
Hahaha, your signature picture cracks me up. I work for the department of defense, and high ranking personnel always (jokingly) accuse me of being a drug dealer or mafia head because of the Lexus's I drive 😂😂😂
Old 08-01-16, 09:51 PM
  #154
doanvien
doanvien's Avatar
My gearbox position and seat heater bulbs got burned years ago (before i bought the car) and how stupid i was, i thought there were not such bulbs on, until I read this thread.
I have purchased the Green Led to install to the seat heater but it is so "green".
/ugly green
Thus I went to toydiy and found out the part number for 2 bulbs: one for gear position and one for the seat heater. It really took time to order and ship . I have to wait up to half of month, so when I was handed over them, I felt so good and could not wait to install them.
5 hours after receiving and getting back after work:
Oh nice green, that color is lovely... I love the original thing...
Old 08-28-16, 09:33 AM
  #155
GaborL
GaborL's Avatar
Can I ask where you got the LED bulbs? I tried looking for them at RadioShack, but their stuff is garbage. I'm looking to do this, but I want reliable, pure white non-pulsating LEDs.
Thanks,
Originally Posted by motohide
Nice Work!
Here's what I did using a little soldiering using 1w 12V LED singles by modding the socket base and removing the filament bulb and replacing it with LED.
No more green and and in place, a nice cool white color switch in the night time.
You can also make them glow orange like an AUDI simply by removing the 'condom' green caps off these filament bulbs too, but I just took the extra step and glued some LED's in place.
Old 12-25-16, 10:19 PM
  #156
Mobius1
Mobius1's Avatar
So the list of lights on page one slightly confused me so here's a snippet of what the tail lights are in what is hopefully slightly easier to comprehend:
Also note:
Door courtesy lights on the bottom of each door are also T10
Front turn signals are the same 7440 as rear.
A 7443 bulb can be used in a 7440 socket. However a 7440 bulb cannot be used in a 7443 socket. This only usually applies to original/incandescent style bulbs. LED's seem to be interchangeable no matter what.
You will need hyper-flash suppressing resistors if you decide to install LED turn signals. [ASIN: B01KZ9AXVQ as an example]
Hope this helps some people. Cheers!
The following 3 users liked this post by Mobius1:
badumtums (08-07-18), danforth (08-15-22), OjaiRoy (03-21-20)
Old 03-31-17, 10:35 AM
  #157
Hagar
Hagar's Avatar
/ugly green
Care to tell how you replaced them, difficulty, part number ect...
I just discovered after having my 04 Lexus LS430 Ult for a month, these were to suppose to be lite.
And did your heater switch background just look in vivid color or is the stock color green? If you modified it to look that uber cool, pray tell how.
Dave
danforth (08-15-22)
Old 05-18-17, 10:16 AM
  #158
Hagar
Hagar's Avatar
Okay it was easy to figure out the heat switch lights. Looks much better now.
So, I was wondering IF the ignition key ring has a light in it as well. Its the last one I might have to replace if it is. And if so, how to replace?
Its dark at night.
Old 09-15-17, 10:37 PM
  #159
Mazamin
Mazamin's Avatar
Default Rear Interior Light
My experience to get to the light bulb of the Rear Interior Light also known as Rear Personal Light of my 2002 LS430:
First I tried to take out the whole thing by unscrewing the bolt inside the hanger. This is wrong and should not be done. Instead focus on the clear cover: There is a small (not easily detectable) grove on top middle of the cover. I put a tiny flat head screwdriver and pried the cover downward hoping that the cover would come off. It did not work. Then I pried it upward by applying some force to the plastic frame around the cover to open up some space around the cover and at the same time used another tiny screwdriver to pry the cover off and it worked. The light bulb comes of by a counterclockwise turn.
Pappadock6 (12-12-21)
Old 02-26-18, 03:25 PM
  #160
Miklosfb1
Miklosfb1's Avatar
Thanks for this thread and info. This was the first "mod" i did. Came out awesome and especially easy with the mirror puddle lights with the pointers, just missing a few other bulbs on order.
Question 1 - I know you should run the HID kits for the fog lights, but if i just want the look of the LED, will just replacing the bulb to an LED be fine? The vehicle is hardly going to be driven so the fog's wont help in my type of driving.
Question 2 - Do you know if the bulb is replaceable for the Temp Controls on the side of the dash? If so, how do they come off?
Thanks again for all your great comments here as well.
Old 02-26-18, 03:57 PM
  #161
05ls430518
05ls430518's Avatar
Originally Posted by Frankg2
Got it, thanks. I'm still not sure I understand the concept of HID LED (the ExtremeBrightLEDs offering) but at least I better understand my options here.
Think of it this way leds produce a puddle of light, hids project farther, and halogen bulbs are a base.
Think of leds as a bucket full of water you throw it covers more but does not go very far,
Hid's are like hose with a handle you squeeze and a jet of water comes out precise and goes far
halogen bulbs are like a normal garden hose on with water coming out of it
Sorry if this isnt the most well worded anology I am just trying help you understand in a way that is not confusing.
Old 05-18-18, 09:16 PM
  #162
Ralo14
Ralo14's Avatar
Some of the links in this thread are dead. Where is a good place to get the led bulbs? If led bulbs are added to any of the exterior bulbs will they cause any malfunctions? Thanks
Old 05-22-18, 05:59 AM
  #163
XenonDepot
Former Sponsor
XenonDepot's Avatar
What year is your LS? Take a look at our vehicle lighting guide to see what bulbs you may need. As for the error code or malfunction, Lexus vehicles are not equipped with this feature so you don't need any extra resistors or canbus to prevent error codes.
Danny
Old 06-05-18, 06:41 AM
  #164
roumieh200
roumieh200's Avatar
Originally Posted by RomanTPA
I GOT THE LEDs FROM THIS GUY.. I WOULD RECOMMEND HIM FOR THE QUALITY VS. PRICE
Exterior Mirror Lights (the easy 5min way)
0. IF YOU DO NOT READ THIS OR BE GENTLE, YOU WILL ****** IT UP
1. You will need a tiny pry bar and/or 2 credit cards
2. Slide the card at an angle starting from one corner up until the entire credit card is in (see pic)
3. Pop that side of the light housing out pass the trim thats holding it up
4. With second credit card, following step #2, slide the card through
5. While prying on both credit cards slide them toward the door of the car.
6. Once the end has completely popped out, slide the housing assembly toward the door
7. Carefully pull the assembly down
8. Once cleared the mirror, turn the pull off the light assembly from the bulb base
9. Bulb base can only go back in one way.
10. Replace the bulb with LED, then start putting everything back together
11. Put the end closes to the door in first
12. Work your way around with credit cards again to clear the trim that holds the housing in place
After popping it out
side look
look at the clip from inside
Old 06-16-18, 04:57 AM
  #165
johnnylt
johnnylt's Avatar
I can’t seem to get the lense out with two credit cards for the puddle lights under the outside mirrors any suggestions
Quick Reply: HOW TO: LS430 Interior/Exterior Lights/LED w/Pics & part#s
