HOW TO: LS430 Mark Levinson EVERYTHING w/Pics & part#s
#46
I have another ML Subwoofer question. I did the silicone fix and it improved 80% but I still have some rattling under higher volumes. I have a installer who looked at the speaker and is willing to refoam as well as recone it for me. I called all the speaker shops including speaker exchange and none of them will recone this speaker. The installer believes that there should be a cone that would fit and pretty much give the same quality sound that the original speaker had. Is this true or will it change the sound quality of the subwoofer. Is there a univeral 8" speaker cone out there that should work? Are there specifications for the cone that must be adhered to to do the job and keep everything original including rear grill without any deck modifications? I do not want to change the speaker to anything other than the ML with the factory voice coil intact. Thanks all.
#47
*silicone "fix" is NOT a fix, its same as giving a band-aid to someone who lost an arm
*when you replace a cone you replace EVERYTHING except frame and the magnet
*re-foam and re-cone will cost $250+ if you even find a place that would actually touch Mark Levinson
*you can find a brand new ML sub on the internet for under $300 if you REALLY care about OEM
*the subwoofer post, explains what you need to look for when getting aftermarket sub
hope that helps
hope that helps
#48
hope that helps
hope that helps
#49
yes, paypal me to coRoman1@yahoo.com and also PM me your shipping address here
(if its 8" and has the "M" shaped foam) it should fit
P.S. update on my 8" ML sub: its still working like a champ
#53
was 190 shipped for me. but nav tool dont support audio like other brands. on the other hand, it switches to back up cam automatically, unlike the other boxes
#54
yeah no audio video only. had to use another brand aux interface for the audio feed. but i do remember the box had a wire to hook up to reverse wire so i think it is the same.
#55
New here guys but looks like you know everything about the ML systems. I have a 2005 LS430 that out of the blue yesterday no sound comes out of any of the speakers. Don't know if I did something or it's defective. It will play for a second or two when you turn the ignition on but once the Lexus "boot screen" displays no more sound. My touch screen also doesn't make a sound when you touch it and I can't remember if it ever did. Don't know if it's related but thought I'd throw that in too. It does this no matter what the source is. Help
#56
edit: before pointing fingers...
0. Is your radio even on? (dont laugh, it has happened)
1. after lexus "welcome" screen does your nav screen come up?
2. can you cycle between the different menus on the screen?
3. if you lower the volume to the lowest setting possible without turning it off with it work?
4. have you modified ANYTHING in the car in the last month?
5. assuming you nav works, can you hear the annoying chick?
6. do you have an after market sub?
7. have you replaced any speakers?
8. have you checked your fuses?
My recommendation for this type of issue is to take it to a respectable audio or car electrical shop.
Because troubleshooting issues like this...well.. its like asking a blind child who took his candy.
#57
Roman,
Thanks for the quick reply.
0. Yes, I've turned it off & on a # of times.
1. Yes, It does and functions properly
2. Yes, I can do everything the unit allows just don't get any sound after that first second or so when I turn the key on. It's like it's muted or something.
3. No, absolutely no sound at max. or min.
4. No, I was listening to the radio driving when the volume disappeared. Thought it was the station but changed to another & to XM, CD, tape and nothing.
5. Yes, I can hear her, I can hear phone conversations as well.
6. No, completely stock.
7. No, all stock as well.
8. No, I figured since I have sound when the ignition is first turned on and all other functions work properly it must not be a fuse.
I appreciate you trying....Looks like I'll drive in silence to the dealer or an aftermarket audio shop as you suggest.
#58
yeah, you got an odd one. im not sure if nav voice goes through the main amp, if it dont, than its most likely your amp went out. i would take it to a shop that deals with car electronics see what they say.
#59
Doesn't that seem unlikely since I can hear the audio for a second before the welcome screen comes up? I went to an aftermarket car audio guy today and he's dumbfounded. Said to go to the dealer. Guess that's my last option. Pretty crazy. My first post here and I've stumped the expert....
