DHC-Limited Rossa Version
Alternative to Datasystem air controller...
The Lowdown pursue that quality. DHC-VERSION ROSSA LIMITED is balanced at a high level of ride comfort and handling that develop the theme, achieving a comfortable driving unprecedented Lowdown. Easy to many useful functions, which allow control of Lowdown further limit the suspension stroke, and high-performance Easasukontorora.
■ Independent front and rear ride height control 16 steps
The processing speed microprocessor, Easasu control the ride height of the car quickly activated. The independent front and rear ride height control, LOW9 stage, HI6 stage, NORMAL can be adjusted in 16 steps.
■ The balance right
Perform minor adjustments to ride height even when the error occurred on both sides. Independent front and rear adjustment range (only 4 sensors car) to be done in three stages.
■ Mode setting safety requirements
Protect the ground clearance in accordance with safety regulations, that support the inspection also. Of course, you can remove to lower ride height than the setting.
■ Select Function
Memory can be up to 3 different height settings. Is a useful feature when the vehicle height according to the scene 使I分Ketai.
■ EX-LOW (extra low) Features
DHC-VERSION ROSSA LMITED, in addition to the normal range of height adjustment, and to build up extreme Rodaun extra "LOW" are features.
■ Automatic Speed Control function
When the set speed is the ability to automatically switch the ride height. This is useful if the ride height 使I分Keru on the streets and highways.
■ One-touch feature normal return
State set Lowdown height is a function to quickly return to normal ride height one-touch button operation. Essential features, such as when passing through a crossing pass and the road construction.
■ Rokkukyansera Features
HI-LOW lock prevents the suspension. Problems without worrying about is the ability to enjoy the kind Rodaunkontororu peace.
■ The balance right
■ Select Function
No idea, I just came across it in my search across some Japanese websites. Without actual testimonials from people in Japan that have used this, it's kind of a crap shoot on how it compares to the Datasystems unit.
Like REV-01 said, it reminds me a lot of controller way back. Field was pushed away in a wave of DataSystem popularity and started to disappear in a market place.
I've checked the biggest Japanese car website "minkara" and searched on parts reviews (they have over 2 million reviews on parts) and found only 3 reviews on this DHC unit.
All states that the unit does what it supposed to do and has not mentioned any negative points. For the price, this may be a good alternative.
Finding a US vendor who carries this item will be difficult and who know what the total cost would be shipped to your door steps.
suka4thong
General Classifieds
05-24-10 01:05 AM
GS300Rich
12-17-08 04:42 PM
rgchevy1
15
06-13-07 11:49 PM
