04+ Transmission fluid change - how much?
I found few threads about it. Including this very detailed one:
transmission-fluid-change-interval post 3377113
It says how, now I'm just wondering how much should I expect to pay to get this procedure done at the dealer. (How long does it take to be done properly)
Regards,
Regards,
DIY = 20-30min
Shops = 45-90min
Dealer = 6 hours to 3 days
The 04+ is not as easy as for other cars. The so called sealed transmission makes it a bit harder. Just reading the "official" procedure from the thread mentionned above took me 30min. (Barely kidding)
Any comment from someone who actually got it done?
All they do is unplug the ATF line coming from the tranny going into the ATF cooler and the ATF line going from the cooler into the tranny pan and plug them into a machine that has one empty tank for the old ATF and another tank of new fluid. You dump in x quarts of new ATF into the clean fluid tank, turn on the engine, and let the tranny suck in the new fluid while spitting out the old fluid. Presto! The charge is around 1 hr of labor plus the fluid (on discount, the fluid is around $8-9/qt for WS, meaning retail will likely be 2x that). I know when I had my LX tranny fluid changed 3 yrs ago, the Toyota dealer charged around $5/qt for T-IV ATF while Lexus charged $10/qt (x 12 qts!). I'm guessing the tranny capacity of the LS is around 7 qts. I will likely get mine done this fall, as the fluid will be 5 yrs old despite having only 27K mi on it...not good to run any fluid too long, IMHO.
i didnt notice the "'04+" i did couple of <'04 at my old job and we just hooked up the pump that we had and flushed it.
Hmm I am not sure I ask them how much to drain the fluid and replace with fresh new fluid and that was what I was quoted. the dealer is BridgeWater Lexus in NJ. I guess I will get the full details once I get their on Monday and let you know.
http://www.bullockcity.com/pricemenu.html shows the Canadian prices for taking it to an independent shop.
What did the NJ Lexus dealer do for $135.00?
For that price, I bet they just drain & fill the pan (< 2 qts). The WS ATF retails for like $12-15/qt alone, plus labor for ATF change is typically 1 hr @ $100-120/hr. The total capacity of the system is around 5.6 qts, so the dealer charge for fluid alone should be around $75, plus 1 hr labor (say $120), plus the shop supplies/misc charge and tax. I estimate for a full change, it should run $200-220+tax.
PS: the '04-06 LS's have fill and aoverfill plug (bottom) on the ATF pan...just no dipstick in the engine compartment. If you use the machine, you first put in 5 qts, then remove the overfill plug and fill until it it drains out the overfill.
writes123
02-13-14 08:01 PM
