LS 430 starting problem 2002
Hello guys
im a newbie here
I have this LS 430 that caused me a lot of headache to fix and get running smooth
the problem started with cylinder misfiring
I used OBD to check
errors were
misfiring detected
cylinder 2 misfiring
cylinder 7 misfiring
Plugs are in new condition
Ignition coils all operate in very well manner
the problem in the vehicle has developed over time
now, whenever the engine is started, it starts and shuts down
thnx to all
im a newbie here
I used OBD to check
errors were
misfiring detected
thnx to all
Hello guys
im a newbie here
I used OBD to check
errors were
misfiring detected
thnx to all
im a newbie here
I used OBD to check
errors were
misfiring detected
thnx to all
I'd suggest switching the coils with the ones working.
IE. #1 with #2 and #7 with #8
If the misfire follows the coils, then, you know that the coils are the issue. If the misfire does not follow, then you know it's to do with plugs or something else.
Brian
senprv
07-18-16 12:55 PM
