52K and this already?
#47
This is what I bought today and used a little bit of based on the recommendation of Mobil 1 ATF...
![](http://www.w124performance.com/images/tools/chemicals/M-1_ATF_new_front.jpg)
![](http://www.w124performance.com/images/tools/chemicals/M-1_ATF_new_rear.jpg)
However, someone above said that you can not use Dexron VI in power steering systems. So do I need to go get something else? This Mobil 1 says its pretty much compatible with everything and "Recommended for use in any power steering unit where a DEXRON or MERCON fluid is recommended". I sure as heck could not find ANY Dex III in my local AutoZone.
So did I uh... just break my car? I barely got one evacuation and refill done so far (there was still some old fluid left in the cavities of the canister).
Andrew
#48
yep - I agree that's the right stuff.
#49
So after 2 whole bottles worth of mini flushes, my fluid is getting better, but nowhere near perfect. I have been doing a mini flush about every 50-100 miles, or once a week. Every time I look at the fluid coming out, it appears red coming down the clear tubing into the collection cup, but as it gets full, you can see that it is still quite murky and still does not allow light to pass through like clean fresh fluid does. I guess I will keep on as it can't hurt. How many bottles have others used to do the mini flush? it appears at least in my case, that it could take several bottles to clear things up to the point of satisfaction. And yes, I am aware that a proper flush would take care of it, but I am not disconnecting any hoses on my car, and like the safe and gentle nature afforded to me by this method.
#50
I used about 1.5 bottles on my Highlander before the PS fluid looked fairly clear. Maybe 5 or so drain and refill cycles. I did it at 52k miles on the HL and its OEM PS fluid was just turning brown.
I know I am stating the obvious, but the number of drain and refill cycles required to clean up the fluid in the system depends on how dirty the fluid was to begin with. It would be interesting to hear how many drain cycles it will take to on avg to clear up the fluid in an LS with let's say 50k miles.
But I don't think you need to get the PS fluid absolutely pristine for it to be in way better shape than when it is black and dirty. The system seems designed to work OK with dark dirty PS fluid, so running relatively fresh fluid in it (after 5-6 drain and fills) is likely a huge improvement and will extend the life of the PS system out to where its a non factor given the life cycle of other major components.
#51
#52
I use Redline ATF for my PS fluid. You can still buy redline w/ dextron II (i started using this). It's a bit thinner than the Redline D4 (specifically says toyota dextron II compatible on the bottle). I used the D4 since I was living in AZ at the time. Now that I'm in a cold climate, I'll switch back to the Redline ATF w/ dextron II.
And BTW, when I bought my LX CPO (49K mi, 3 yrs old at the time), the PS fluid was black and smelled burnt. In fact, it was so gone it left a permanent dark stain on the inside of the PS resevoir. Even when I bought my '05 LS CPO w/ 21K mi, the fluid was dark, but at least it didn't smell burned. I believe lexus only check the PS fluid LEVEL at CPO time. The reason is there is no written service replacement interval on the PS fluid as there is with engine oil or any other fluid. There should be, though. My local dealer in AZ was saying they recommend changing the PS fluid about every 35K mi. I think it should be more often than that, more like 30K mi.
#53
you cant flush the system (coolant, or power steering ) via a reservoir. The fluid doesnt circulate through there. The reservoir only dumps fluids if the rest of the system gets low.
