mud flaps
BTW, i got mine from a seller on Ebay located in Japan. Little bit pricey, but this guy has great communication and fast shipping - http://motors.shop.ebay.com/zeroism702/m.html
Except that the part numbers are the same - except for the color code suffix - for all model years (01-06) of the LS430. Unless the part number website I've used for some years is wrong ... I have not found it to be incorrect in the past.
LS430 EURO spec(08.2000 - 07.2003) rear mud flaps in black 76626-50050-C0
LS430 EURO spec(07.2003 - 08.2006) rear mud flaps in black 76626-50060-C0
Part numbers are different, but i can't say for sure they are not interchangeable! You're using link Perhaps the part web site i'm using, is not correct. Peace and nothing personally ;]
For example:
My neighbourhood Lexus dealer said he could order these
The cost was
$ 211 each for the fronts
$ 228 each for the rears
Total with tax is $ 992.14 wow.... anyone have a used set for sale ?
The cost was
Greg
I found out that Toyota no longer makes mud guards in our car's color -- code 072 -- so I bought a set of brand new guards in code 062 on eBay for a fraction of the cost of what they would have been at the local dealer. Codes 062 and 072 are pretty close in color, but I'm going to re-paint them anyway with custom-mixed base and then clearcoat.
Still have not arrived yet, I'll follow up with them and see what the time frame looks like. Originally 6-8 weeks for delivery so I haven't exactly been waiting on pins and needles... I'll let everyone know when I get them.
Sorry this wasn't helpful.
I'm finally going to install our newly re-painted mud guards, but the installation instructions are in Japanese. Unfortunately, I don't read Japanese. There are illustrations of generally how to do it, but I think I'd do a better job if I had the English instructions.
Does anyone have a pdf of those instructions, or a link to a site that has those instructions?
Thanks for the help.
You will probably have to remove the back wheels but there should be enough clearance to install the front mudflaps if you alternately turn the front wheels all the way to the side.
A bit of drilling was required on my 90 and/or 00 LS but don't know if that will be required on your LS430 ... but how to do that was intuitively obvious too. If installation is like on my 00 LS400, you will need a set of small metric hex wrenches. Your LS430 mudflaps may have come with fasteners that will replace existing ones and they may be slightly longer to allow for the thickness of the mudflaps.
I don't remember much about the 90 LS mudflap install (21 years ago!) but I remember the install on my 00 LS was super easy - maybe about one hour total.
