Looking for Mark L Audio system for 2001-06 LS430 UL
Anyone out there selling a Mark Levinson audio system for 01-06 LS430 UL? Please reply. Thanks.
Hey tham430 I have a mark levinson no nav headunit from my 03 ls430. I swapped it out for an aftermarket one. Everything works perfect. I'm planning on selling it just haven't got around to it.
Check it out
http://www.youtube.com/watch?v=SJTqWgkj5H8
the only thing I needed was the clips from the side but if you're replacing with yours you should have them.
Check it out
Hi flynnjon, Mine is a Ultra Lux so it has navigation. The only part I actually need is the flat ribbon cable that runs from the tuner to the cd changer. It's about an inch wide and 4 to 5 inches long.
Not sure yours would have that exact cable or not. If you pull the unit out it is behind the tuner plate on the left side if you're facing the unit.
I only need that part, but may be willing to buy the complete unit. Obviously if anyone out there has the exact unit it would be better, but I'm flexible. Thanks very much.
i have a factory head unit i could sell. not too sure if the tape deck worked. from what it sounds like you just need a wiring harness. let me know if you interested. the reason i have this head unit is we put a aftermarket stereo into my 2001 ls430 ul with nav.
thanks,
scott
thanks,
scott
khoop
09-06-14 02:39 PM
splitfire
07-12-04 09:35 PM
