Driver side mirror not moving up & down!!
Hi, I have a 2006 LS430. The driver side mirror does not move up and down, but it does move left & right. The passenger side mirror works ok.
I heard this is a really common problem. I went to the dealer and they said I need to replace the entire mirror housing, including the outside enclosure. It will cost about $700+.
I put my ear on the enclosure when pressing the mirror button and I don't hear any sound from the inside when pressing up & down.
Does it sound like a motor problem or a switch connector issue?
I actually took the switch apart and cleaned the contacts. It looked pretty clean to begin with. Do the switch contacts need conductive grease? I am afraid of putting conductive grease on the contacts in the switch for fear of shorting things out. Please help!
By the way, when I press the up & down switch on the driver side, I do hear a click from from somewhere inside the door. Also when I put my car into reverse, the driver side mirror does NOT tilt down. The passenger side does tilt down.
Hmm... the "common problem" related to this IS the switch itself, and it appears you have already taken it apart to clean it, which is precisely what is advised here. I think the fact that you are hearing a sound in the door area directly correlating to the button pushes on the switch rules out the switch for the most part, especially since it works on the pass. side just fine (IF the switch were the culprit, it would be the actual L and R selector that would be suspect here, as the 4 way push button works the pass. side without issue). The next common mirror issue is the mirrors pointing straight down to the ground and that's not what we have here either.
While I am not entirely certain exactly what is going on, that should help rule out some of the more common failure points. As for the grease, it shouldn't cause any harm, but since there's so much evidence against the switch itself, I don't think it matters either way.
My driver's mirror was acting up a bit yesterday. It was pointing a bit down for some reason (I don't have the backup tilt activated). I couldn't get it to move up or down. However, once I moved it back and forth horizontally a bit, the vertical adjustment started working OK.
I have the exact same problem with mine only that it is the pass side that is giving me the trouble. There seems to be a loose connection somewhere between the door and mirror when it comes to up and down motions. Gonna have to get to the bottom of this real soon because im getting tired of it tilting in reverse but wont return to the original position when put in drive.
Strange thing is that I hear a clicking sound coming from somewhere within the driver door when I press the mirror switch to move the mirror up & down. Anyone knows what is causing the sound? I am sure the sound is not coming from the switch itself, which does also makes a slight clicking sound when depressed.
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
If it is a connection problem between the relay and the motors in the mirror, how should I fix it? I saw someone else post an interesting post detailing how to take off the mirror and get behind to the motors. Has anyone tried it? Could the up/down motors be bad?
If you do have Lexus replace your entire mirror be sure to ask for the old mirror back. It would probably be an interesting and relatively easy project to take it apart and fix whatever is wrong and then your have a spare. I had Lexus replace mine under warranty about 2 months ago but I wasn't clever enough to ask them for the old one back..wish I had.
Jay - good point, you may be right for CPO warranty work. But if someone pays to replace a mirror assembly it would be a good idea to ask for the old one back. At a minimum they could sell it on ebay.
