More cool stuff found
Everyone keeps finding cool things on the LS (secret compartments under seat, turning on radio with steering wheel control, etc).
I've never seen a fresh air cooling vent for the brakes on a mass production car.
Way cool. (pun intended)
Having discovered that. I have a question. Does it really make a difference?
1. The rim practically covers the rotor.
2. The rotor is more near the outside face of the rim.
3. The 5 spoke rim is already open enough for air dissipation.
So unless I brake while I'm turning, there's no ram air effect.
Every little thing helps theory?
AHHHH DUH !!!!!! I should have spent more time thinking about it. High pressure is created by both sides of the rim (one from the open 5 spoke and one from the ram air). Low pressure is created inside the rim.
Think of it this way. You're driving 60mph on the highway. You have the driver side window open (5 spoke side). Even if you open the back driver side, you don't get much more wind.
Now if you open the passenger side window (ram air vent), think of all the wind you're getting in the cabin.
Ahhh DUHH... I'm so stupid
Pretty cool discovery - thanks!
More proof to show how nicely engineered these things are.
Since this is a thread about other cool features, does anyone know other functions of the key fob? So far I have discovered that:
1) Holding unlock for several seconds rolls down windows + sunroof.
2) Taking the actual metal key, putting it in the door, and holding it in the lock position will roll windows up/close sunroof.
I ask this b/c the guy I knew in high school could roll his windows down and turn on his radio from the key fob. His was a UL, but I don't think there is a diff in key fob function.
Whats wrong? Its over 90 degrees here in wonderful Puyallup.
it must be termed on for it to work. To tern it on you need touchscreen. As many other options.
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Do you happen to be using the valet key or a regular key? I've never tried this feature with the valet key but I wouldn't be surprised if it was disabled on it.
b2designs
Club Lexus Vendor Marketplace
240
02-16-18 09:03 AM
dbs600
02-09-15 07:52 AM
