Secondary Sun Visor
Secondary Sun Visor
Has anyone discovered a front window sun visor to supplement the existing ones? My wife loved the ones on our Caddy Deville and Mercedes. I think Lexus made a mistake in overlooking this good feature.
Do you need more shade on the windscreen only,or the side windows as well?
If it's the front,the factory windscreen has UV cut,so you won't get heat coming through it,just light. If that's the issue (glare),you could get a small tint bar put across the top of the screen.
If it's the side,your options are to tint the windows (if you haven't already),and/or go for curtains.
Justin...
Justin...
If you are referring to the side extensions on some GM products, remember that with the LS430 you can swing the visor to the side and then slide the whole visor toward the rear of the car - it slides along the top pivot bar.
Also, the LS430 has the mini visor that swings down over the rearview mirror. (It's not much, but it is cute.)
LexusinTex
04-16-14 06:36 AM
95BlackSC
SC- 1st Gen (1992-2000)
22
11-29-04 07:30 PM
