Need procedure to reset auto up feature
Had to replace the driver's glass yeaterday and after it was installed, whenever I hit the auto up the windows goes all the way up and then rolls back down about half way. The manual up is fine. I think the system needs to be reset. Is their a procedure for this or must I take it into the dealer. I did a few searches but foud nothing concrete to try. This is only affecting the window that was replaced.
https://www.clublexus.com/forums/ls4...placement.html
As long as you did not detach the motor from the regulator, press the down switch all the way down and hold until the window is fully open. Lift the up switch and hold until the window is fully up; continue holding the switch up for a few seconds. That should do it.
UNOHOO
RX - 1st Gen (1999-2003)
07-14-09 12:10 AM
