Is the cabin air temperature adjustable?
In other words, I dialed in 82 degrees tonight, and it came out slightly warm. 85 was slightly warmer. Neither as hot as I believe it should be. Can you tweak anything on these systems?
Agreed. But this vehicle shoots out much colder air than my wifes 470. I wouldn't get warm very quickly when it gets much cooler outside. I'm thinking I may have an issue.
If its not getting hot very quickly you may have the radiator termistat stuck open. That's generally how they fail when they do go bad. I think its a relatively cheap repair on the LS .
Setting the vents to re-circulate the air will help it to warm up faster.
If it takes more than a couple of minutes to start pumping out warm air,there is likely a heater issue,as Jabberwock suggested.
Justin...
Justin...
skassamali
09-22-11 07:10 AM
