Supercharger like whining sound
When given some beans, and the RPM's go above 3k you hear a Supercharger type whine coming from the front.
What could cause this? I googled and someone said it might be a pully or something, I am not sure.
Edit: it happens at above 3k RPM even in Neutral. Car is at 80k
Update: Video added
http://www.youtube.com/watch?v=aGtJIgNU-kc
Update: Video added
Sounds like a belt to me. Had the same issue a while back and it was a belt. Not a major issue if thats what it is buddy! All the best, hope things work out for you. L.G.N.M
Hopefully just the serpentine belt or tensioner pulley. I've heard this before from a bad alternator bearing when it was in its early stages of having problems though.
Ah ok will bring this up with the dealer we have the factory extended warrenty which covers like a new car so they should fix it no problems.
Correct - the SS version had just the bump in the hood. The Super Sport Ninja version had the big honking hood scoop, taller rear tires, 3/4 race cam, and ceramic coated headers with LOUD sidepipes. My wife put her foot down on that one because of the lumpy cam at idle and fear that she'd burn her leg on the sidepipes.
(Sorry, can you tell I used to live in the vette world? Imagine if the LS430 was made in the late 60s and early 70s as a muscle car...)
Well, My dad went today and they changed the oil then they said they "could not replicate", oh man how many times do we hear that eh?
Finally got my camera, here is a short video I made. Play in 720p so you can hear it at its best audio quality.
Would be awesome if you guys with Stock LS430 can do the same, and see if you hear what I am hearing.
as I dont drive the car I am not sure if this is normal...
Cam Belt = Timing belt
Now, the noise would not come from the belt itself but from one of the pulleys or maybe even the water pump (although I doubt it is the water pump)...
If you want to change the whole timing belt kit, then it is the belt + all pulleys + tensioner + water pump...
i love watching the mpg go down in front of my eyes
