rear control arm replacement
My 05 non-air suspension:
Rear Left
Camber -1.5 (spec range -1.8 to -0.8)
Toe 0.10 (spec range 0.05 to 0.25)
Rear Right
Camber -1.8
Toe 0.10
Rear
Cross Camber 0.3 (spec range -0.5 to 0.5)
Total Toe 0.20 (spec range 0.10 to 0.50)
Thrust Angle 0.00
So in my case the only thing that is borderline is the rear right camber. Everything else is within range of where it should be.
Your rear left looks like a problem - if these same values apply to your car. By my chart you are out on both camber and toe.
Rear Left
Rear Right
Camber -1.8
Toe 0.10
Rear
Thrust Angle 0.00
rouxtoy
07-13-16 06:35 PM
