Tilt steering dead - what are my options?
I know the tilt mechanism goes out -usually- because a nylon gear gets stripped, while everyone say the telescope function dies because the motor goes bad.
I have to wonder if the real problem is that these parts, and the screw-shafts, levers, and whatnot, never get any post-factory lubrication.
Small motors and gears working against increasing friction are bound to strip or die.
While everything is working fine, it might be great preventive maintenance to get inside there with a spray can of silicone lubricant.
I don't think it could hurt anything, and might bring some systems back to life <shrug>.
Can anyone tell me where this fuse box and fuse is located on a 1998 GS 400? Neither my drivers side or passenger side fuse box looks anything like this. Thanks. Never mind. I found it. In the GS 400, the fuse is #25 in the passenger side kick panel fuse box. Only problem is that this fuse also controls the power seat system.
Comments on Tilt Motor issues
1. The nylon gear issue was LS400s, not LS430
2. Turning off the feature is done via computer. Buy your own techstream or I prefer the bluetooth dongle and (Carista?) app. The app is $10/wk, but just buy a week. It also lets you configure all the other computer controlled features like seatbelt buzzers and door chimes et al.
3. I was looking for info on how to REBUILD one of the motors or taking one to a generator/motor shop. Anyone done that?
Mine has also suffered the same fate, lost both tilt and slide function. I pulled the slide motor out and disassembled it to see if there was anything obvious. It was all nice and clean inside and nothing looked wrong.
In the end I left both motors disconnected and have manually adjusted the column.
Would be nice to have a how-to on fixing them as even second hand replacements are expensive.
Hi all,
Sorry to bump an old topic. My 01 LS430 has the same issue. I have zero movement of the steering wheel (no in and out, and no up and down).
I checked all the fuses (there are three) and they are fine. Looks like the motor needs replacement. Pardon my ignorance but my question is. How many motors are there in the steering system? Is it just one tilt motor that does both operations? Or do I need two tilt motors? (Or are they both different motors altogether?)
TIA.
TIA.
Hi all,
TIA.
TIA.
There are two separate motors; one for the tilt and one for the telescopic. So, you can't get any movement at all on the wheel by moving the control switch? The only reason I ask is that there is a way to disable movement of the steering wheel whenever the vehicle is first started or when it's shut off by setting an option via the diagnostic software but even if this is set, you should still be able to control the wheel position with the control switch...
telescopic motor thread
If you look two posts down from there I also make a suggestion about the tilt motor but since I haven't had to change mine out I cannot verify using the Land Cruiser part in it's place...
cvas (09-18-20)
kevin3344
10-20-18 12:51 PM
willcrets
13
02-28-18 05:55 AM
tpatt6969
02-17-14 12:40 AM
Sentinel
07-18-11 06:40 AM
OneRedSc
SC- 1st Gen (1992-2000)
07-14-11 08:45 PM
