Rear camber adjustment
i have the rear lower control arms that have no adjustment they are just 5mm shorter than stock, they also make ones that are 5mm more than stock for 5mm added negative camber. they were like $130 or so for the set and i was charged like 75 for the install even though with a lift i could have easily installed them myself. then i got an alignment and was all done for like $300 which is prolly a lot cheaper than even purchasing the nagisa ones if i'm not mistaken...
Waijai, my correct stock camber specs are
................. independent ..... Lexus
left rear.......... -1.5............. -1.9
right rear........ -1.9..............-1.8
and yes, Lexus advised me to do a $1,300 repair to bring the rear into spec !
I have an 06 with staggered 20's and i am having the same rear inner wear problem, In reading the post, i understand that there are 3 lengths (The lengths are: Length = 441.5 mm, Length = 446.5 mm, Length = 451.5 mm
) Which one should i get for aftermarket 20's (Asant) and Does anyone know the OEM part number?
ahhh good question... here is your answer: the stock arms are 446.5mm long. if you want more negative camber you get the longer arms (451.5mm), and if you want less negative camber you get the shorter arms like i got (441.5mm), no but seriously i do have short arms
So if i am wearing on the insides of the tires and i buy the replacement arms, am i trying to increase the negative camber or decrease the negative camber? I am sorry if this question seems elementary, but i just want to make sure i buy the right part.
I am running 275/30/20 on rear
thanks all
thanks all
correct ^ ^ ^, but please note that if you were super flush then by putting shorter arms you will then rub. if you pull in 5mm on the bottom of the tire towards the car you push out the top of the tire 5mm towards the fender or away from the car. just know this prior to doing this mod. but i'm sure those who know enough to be flush would hopefully already know that shorter lower rear arms would take away 5mm of clearance.
