Rear camber adjustment
#46
Hi guys, looking at the other arms, if the tapers line up this should be no problem. I received the camber arm today and I will design thr two tabs this week. My new tapered studs and high misalignment rod ends work great in this application, should be a direct fit.
I will post up as soon as I have a proto. maybe a few days.
Fig
Fig
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
![](https://www.clublexus.com/forums/signaturepics/sigpic106840_3.gif)
#47
Fig
Fig
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
#52
here is a rendering of basically what I have so far. These two tabs are out for lasercutting.
![Name: arm_camber_RRLS430-1.jpg
Size: 24.4 KB](https://www.clublexus.com/forums/attachments/ls-3rd-gen-2001-2006/434720d1501366727-rear-camber-adjustment-arm_camber_rrls430-1.jpg)
__________________
#58
yeah its a little more welding than my other links with the tabs etc and I will need to see if we can get by with 5/8" rod ends vs 3/4" Just as a target I would say around $250 given the rod ends I am targeting now. plus or minus. I also have a few more options for on-vehicle adjustment.
__________________
#60
yes eventually all links, the sway endlinks should not be a problem either.
__________________
