Removing Center Console Cover
Old 02-05-11, 08:55 AM
jayclapp
jayclapp's Avatar
Originally Posted by dtaylor
Yes, you could.
Will this acomodate bluetooth as well? I didn't see anything on it on the site....
I don't think the SL2vi has any bluetooth capabilities. But, the only bluetooth device I use in the car is the cell phone. The SL2vi interacts with a phone call just as the radio or CD play does. An incoming call will interupt the iPod, allow you to make the call, and then resume playing when the call is finished.
That's about all I know about the device and bluetooth.
Old 04-03-11, 04:13 PM
Fourall
Fourall's Avatar
Default Great reply
Hilo,
Great reply. All four screws that attach the armrest to the minge were loose. Followed your instructions and it easy and sucessful. Thanks for the post.
Old 05-28-18, 05:07 AM
clarkent
clarkent's Avatar
[QUOTE=dtaylor;6108439]Chunkyda, The pad has 4 screws holding it to the pivot arm. The only way to get to it is to follow the instructions above and remove the whole assembly which is comprised of the bucket, top tray, sliding bracket, and pad.
It took me about 20 minutes to remove it as per the above instructions. Then I just held the assemply in my lap upside down and took the arm rest pad screws off ...
I'd like to recover lid too but Pictures show removing lot of wood trim around shifter and faceplates, but other posts not clear this is all necessary. Is there a way to remove just lid or lid and box without disassembling all other parts?
Old 05-28-18, 05:26 AM
2KHarrier
2KHarrier's Avatar
I need to do this as my lid is loose from the storage compartment. I don't believe you can get the storage console out without removing the shifter plate and cup holder assy.
Old 05-28-18, 09:33 AM
LSGarry
LSGarry's Avatar
Not necessary to remove wood trim. Check the link below for good instructions. I just did mine and worked like the proverbial charm.
https://www.clublexus.com/forums/ls-...e-lid-fix.html
2KHarrier (05-28-18)
Old 06-04-18, 10:30 AM
Mannyo03UL
Mannyo03UL's Avatar
Default These instructions helped me-03 UL
https://www.clublexus.com/forums/ls-3rd-gen-2001-2006/335082-center-console-lid-fix.html
Old 06-11-18, 06:43 AM
clarkent
clarkent's Avatar
This is very helpful, thank you.
Old 02-20-24, 09:28 PM
liuels
1st Gear
liuels's Avatar
I lost one of the 8mm screws for the Navi Screen. May I know what it the size? how to get one?
RussLS460
06-21-19 01:41 PM
Enforcer84
03-27-18 10:42 AM
rewalker
04-30-17 10:42 AM
patgilm
05-29-15 05:25 AM
jbess
Automotive Care & Detailing
01-22-09 07:36 AM
Quick Reply: Removing Center Console Cover
