Buying an 04, worried about Tire Pressure Indicator
Hi Everyone,
New to the forum. I have been reading lots, just registered. I am looking at an 04 LS430 with 104k. It is the original TX owner serviced at the Lexus dealer. Had the 90k (timing belt & water pump) done at the dealer at 101k. It has always been garaged, but has 3 small dings..front and rear bumber and a small on on the passenger side back door. The power mirror motors were disconnected at the dealer b/c they wouldn't fold back out (dealer quoted 1300 to fix so he just had them disconnect). The low tire indicator light is on, but the tire pressure is fine. Is that a big problem? It doesn't have nav, but does have the premium pkg. They are in their 60s and have taken very good care of the car. He is asking 15,500, does that sound reasonable? Thanks
If the 4 tires have correct pressure, all that needs to be done is to Initialize the TPMS per the owners manual. I forget the exact procedure, but it's in the manual, and you must see the word "Initialize" in the dash display.
The 04s have a primitive TPMS system, with no tire-mounted pressure monitors on any of the tires. It counts wheel rotations. Anytime a tire's pressure is changed, even when bringing all of the mounted tires to the correct pressure, the TPMS system must be "initialized", not just "reset". It's been covered here many times, and a search may bring up the step-by-step procedure.
Walt
Welcome. I'd have it inspected to determine if there are any other hidden gotchas. The TPMS should reset once you follow the procedure. Also, run a KBB on the price as I'm not sure what the value would be with that mileage.
Way (way) up under the dash where your right knee is, there is a **** and two buttons. The **** adjusts the beep volume. The button closer to you is the tire pressure initialize button and the button further away is for the smartkey. Turn the car to on and hold in the button until the tire light goes out, like 5 seconds maybe.
If mirrors are broken, deduct full cost of getting them fixed (700 per mirror) - its not a trivial thing.
Dings can be fixed, if not through the paint, for approx $100/per ding - deduct from asking price.
See if resetting TPMS will clear the error if not something else may be wrong. There are no sensors in the tires - its a system that measures tire rotations. Make sure wheels and tires are all same brand and size.
My advice is don't accept car as is for asking price unless broken items are fixed or offer him wholesale price if he wants to sell with dings and broken mirrors.
Strongly suggest you get the car inspected at Lexus before buying.
To initialize, press and hold (about 5-10 s) the TIRE button under the right side dash bottom (where the volume for alarm is), with key in "ON" position and it should go to "INTIALIZED" when done on dash.
Yes, be thankful for the LS430s "crude" TPMS system as it makes seasonal wheel / tire changeovers much easier. None of that deflate - inflate nonsense that is necessary to teach a pressure sensor based system where each tire is located.
Don't know about earlier, but '04-'06 the TPMS was standard. As many mentioned before, it's not sensor monitored in the tire, it's using the ABS system to monitor variances in relative tire rotation. You should not have a problem with new wheels, just initialize it after install.
You have to open the driver door, get on your knees, put your head on the floor of the car, and look up under the dash by the transmission tunnel. Once you know where they are, you can find them when reaching under from the driver seat.
Put your head down on the floor near the gas pedal, then look up (at the underside of the dash there.
I wouldn't worry too much about the tire pres monitor sys. Mine turned on during the drive from Glenview IL (where I got the car) to my home in Ann Arbor MI on the highway. I almost crapped my pants to be totally honest, but my parents (who were driving behind me) said that everything looked normal. Pulled over and everything was normal. Hit the reset button and never looked back
Good luck, get a pre purchase inspection from Lexus (as many have already said). Drive the car on a mixture of roads to see how it rides/handles. Also, make sure the engine is buttery smooth (shouldn't be able to feel it at all) and the trans shifts without you noticing.
