LS430 A/C evap drain hose/tube
Can someone please tell me where I would find the drain tube that comes off the air conditioning evaporator? I spent the better part of sunday afternoon looking under my car and was unable to find it. Do I have to remove the entire plastic underguard to see them?
The A/C schematic indicates there should be grommets at the end of the
hose(s) but, I don't see those either.
I have searched through all the threads in regards to this topic and have come up empty handed. Any information or photos that anyone can provide would help me greatly.
Thank you in advance.
Im not sure but on hot humid days when i have my a/c on i can see water coming from the passengers side front. Not sure if this is where the hose terminates. But should help narrow down your search.
Thank you. See, I was thinking the same thing but, was still unable to find it. It's been really dry here. I drove around for a good period yesterday and was unable to get the evap to drip.
If anyone else has anything to contribute, I'd gladly appreciate it. Thanks
Thank you for taking the time to send that pic, Jac. That is a drain tube, but not for the AC. Its to drain the radiator. Theres a valve above the plastic cover. Again, thanks for taking the time to try and solve my problem
LS430 A/C Drain Tubes
First let me say sorry for not taking a picture of these as they are really hard to find if you don'l know where to look. Hopefully I can tell you where to look... If you have your LS430 jacked up there are places for a jack or jack stands just behind the front wheels. I'm guessing about 6-8 inches to the rear of those jack points, move in toward the center of the car. You'll see Silver / Aluminum looking heat shields on either side that run down the length of the car between the bottom of the car and the exhaust. On that line I was talking about you'll see a 1/2 dollar size round hole in that heat shield (before you get to the exhaust pipe). If you stick your finger inside that hole you'll feel the drain tube. There is one on the driver side and the passenger side. Sneaky.
You think maybe they could have used another inch of hose so it stuck out the hole... Probably too much wind drag... Good Luck!
pat2555 (06-26-23)
Yes. You are exactly right. Thanks for this. I did end up finding them on my own and using a Toyota aerosol disinfectant flush to the condenser and it worked wonders. No more or little musty smell. I am gonna take some pics and add them to show other CL peeps where they are.
PS - original Lysol disinfectant spray, when sprayed into the cowl opening air intake (base of windshield) does the same thing, additionally kills viruses, and is $4.96 at Wal-Mart for a large can!
Toyota aerosol disinfectant flush to the evaporator - the condenser is in front of the radiator
here on Club Lexus, we pride ourselves on accuracy, what if someone reads your erroneous post, and is planning to change out their condenser, and ends up tearing out the dash for no reason?
That's where the bacteria breed that make the smell.
It's a Toyota kit and inexpensive. They provide a flush for the evap core that is secured with a tube and fitting to the one of the evap drain hoses ... and a cowl freshener for after.
Just spraying Lysol down the cowl does not do the same thing.
You've gotta buy the kit if you want the job done correctly. Especially if you really want to take care of the problem, not just slap a band aid on it.
Changing the cabin filter and using the TOYOTA kit worked miracles for my LS430 and I would do it again. I'm sorry but, I disagree. Lysol doesn't cut it. It's a band aid on a larger AC problem. The foam used acts as a detergent and cleans the evap core of bacteria and mildew. The LS has two drain Hoses. So, once the contents are all in the evaporator, it cleanses it and drains out the other tube, along with excess collected mousture. It was VERY effective. Then the second step with the deodorizer through the cowl made a difference as well. And again, was not very expensive. Toyota marketed nothing to me. I found it on my own and went and picked up. Instead of hating on my thread, how about considering it may be helpful.
The kit is licensed and sold by Toyota. I seriously doubt Toyota would put their name on anything and sell it though their parts departments if it was a gimmick.
pat2555 (06-26-23)
