Who makes Toyota Timing Belt change components?
Who makes belts, water pump, tensioner and pulleys for Toyota/Lexus? Is it Aisin? Has anyone change the factory parts themselves seen the manufacturer on the parts? Thanks!
The replacement belt is marked "Made in the USA" along with the Toyota part number. The water pump casting and box doesn't have any manufacturer identification. The idler bearings are marked "Koyo" with nothing else on the boxes. These parts came from Sewell.
OEM Vs. Aftermarket Parts
If that is the case, why buy OEM instead of a know OEM supplier aftermarket... at half the cost... that is what I am struggling with.
- Aisin makes a kit with the following for $207
AISIN kit includes the following components:
AISIN Water Pump
Koyo Idler Bearing
Koyo Tensioner Bearing
Mitsuboshi Timing Belt
Water Pump Gaskets & O-Rings
- Gates makes a kit with the above and the Hydraulic Tensioner for even less ($167)
Equivalent OEM kit from Sewell with Tensioner (and gallon of Coolant) is $390.
So OEM is double the Gates Kit and probably $100 more than the Aisin kit after buying a tensioner seperately.
I'm leaning toward OEM parts, despite the extra cost as I am saving like $1,500 by doing it myself... just thought I'd ask y'all's opinion.
AISIN Water Pump
Koyo Idler Bearing
I don't know if for instance, Koyo or Mitsubishi, would make varying quality replacement parts to meet a price point for a specific customer specification such as for Gates. I just don't know. But I do know that Briggs and Stratton makes a bunch of identical horsepower engines that will all fit the same lawn mower but the engines are built with vastly different quality components to meet a brands price point.
In any case, I always recommend including the upper and lower radiator hoses and thermostat with gaskets in your parts list.
According to my research AISIN is owned by Toyota and manufactures the water pump. Koyo makes the bearings and Mitsuboshi makes the belt. I bought the eBay kit for $189 shipped recently.
You can indeed pay quite a premium for parts once assembled into a vehicle in Toyota City to get repackaged into a Lexus box to make you feel comfortable.
In truth parts are sourced from a global supply. An A-340 tranny in a older Lexus 400 is also in a Volvo for example. The ZF 26 in my 545 BMW is in a Maserati , a Range Rover, Bentley and the newest hi-po Mustang.
3 perhaps 4 companies make AC Compressors.
I'm sure it costs manufacturers money to spec parts differently as well... not just the content of a part (they to test the part in all configurations they plan to sell as OEM replacements I assume, and that costs money). I think it is unlikely the bearings from the same manufacturer have any variances between components when they both meet or exceed OEM specs... just my $.02. Then again, the price difference in this case is not more than $200 so I may hedge it and just pull the trigger on the Sewell parts for piece of mind and to support a CL vendor... good will all around.
My car has a gates sticker for the timing belt. I know Gates make the OEM belt for Mitsibishi. I guess the quality should be similar if not the same as the OEM belt from Lexus.
Good suggestion Bon. Can you get to these parts easily if you were not doing the timing belt? I am most interested in replacing anything where access is limited unless you're in there for the timing belt change... otherwise I'll save my cash if/when those go bad and replace them at that time.
Is this a deal for 322? it comes with more stuff then the other kits for 189.
http://cgi.ebay.com/ebaymotors/Lexus...Q5fAccessories
lserlohn
RX - 1st Gen (1999-2003)
07-07-15 03:43 PM
belt, belts, change, code, lexus, ls430, makes, mitsuboshi, number, parts, replacement, timing, timingbeltkits, toyota, whomakesgoodtoyota
