Sunroof Rattle
Old 05-11-11, 08:06 PM
Incognito8
Incognito8's Avatar
Default Sunroof Rattle
Now that the weather is getting nice in the Midwest, I'm retracting the sunroof a lot more on my LS 430 UL. Ever since I got the car 6 months ago, I've noticed that there's a rattle whenever the sunroof is retracted, whether partially or all the way. The problem seems strictly limited to the sliding panel on the inside of the car. When I push on it, the rattle goes away. Moving the panel forward/backward doesn't seem to make any difference. No noise at all when the tilt feature is used. Has anyone else had this problem?
Old 05-11-11, 10:28 PM
Vpanin
Vpanin's Avatar
i have the same issue............dont know what it is
Old 05-12-11, 02:25 AM
denIS200
denIS200's Avatar
Denis.
Old 05-12-11, 05:00 AM
caddyowner
caddyowner's Avatar
My sunroof shade rattles when it is in any position other than fully forward (closed). I don't hear it on the rare occasions I have the sunroof open due to wind noise. Since I don't like driving with just the shade open due to glare and interior heating from the sun, I leave it closed most all the time.
Old 05-12-11, 05:45 AM
CarGuy89
CarGuy89's Avatar
The only time my sunroof is opened is when my sister rides with me (I like it quiet and leave it closed). I don't really notice any rattles.
Old 05-12-11, 06:05 AM
Boomer01
Boomer01's Avatar
Mine does it also.
Old 05-12-11, 10:34 AM
StanVanDam
StanVanDam's Avatar
Mine doesn't rattle in any situation, not even full open on the highway. Hopefully it stays that way.
To fix the rattle, you could take apart the sunroof. Pages 4-7 in the attached file would help with the disassembly.
File Type: pdf
Old 05-12-11, 10:48 AM
caddyowner
caddyowner's Avatar
C'mon Stan. If I would take it apart I'd have parts left over, it would rattle ALL the time, and it would leak.
Old 05-08-14, 08:14 AM
Jch
Jch's Avatar
I am having a problem with a sunroof rattle. In looking at the PDF in the above post, the culprit is the sliding roof garnish front on page 3. The drivers side is firmly attached but the passenger side is loose and rattles when hit by the wind when the sunroof is open. I am unable to figure out how to tighten this piece. Any help would be appreciated.
Old 05-08-14, 09:03 AM
empringham
empringham's Avatar
so you guys only get the rattle when its only slid back? odd. mine only rattles when its in the tilted position.
Old 05-08-14, 10:38 AM
ancdmd
ancdmd's Avatar
the sliding interior sunshade is what rattles on mine, drives me nuts all the time.
Old 05-08-14, 01:24 PM
LS430FL
LS430FL's Avatar
Same problem with mine! can't figure it out
Old 05-08-14, 01:43 PM
Jch
Jch's Avatar
I know what is wrong with mine I just need to know how to fix it. The piece of metal called the sliding roof garnish seems to be clipped on one side but loose on the other. No matter how I push I can't get the one side tight. Because it is loose it rattles when the wind hits it when the sunroof is open. When the roof is closed no wind so no rattle.
Old 05-12-14, 01:57 PM
Jch
Jch's Avatar
Well the rattle was driving me crazy so is pulled off the offending sliding roof garnish. It has 4 or 5 clips and the 2 on the passenger side were broken. I could leave it and the unfinished part can only be seen when the sunroof is closed and the shade is open. Or I buy a new garnish for $68 bucks shipped from Sewell and snap it in.
Old 05-13-14, 06:01 AM
Boomer01
Boomer01's Avatar
How were you able to pull off the piece?
Quick Reply: Sunroof Rattle
